KoenE Posted September 26, 2013 Share Posted September 26, 2013 Hi all, My first post on this forum after a long search... I am trying to write a VBA routine wich will return information of objects near an other object. Is there a command or code wich can help me identifying objects near a line? The objects are not always crossing the line, they might as well be parallel. Thanks Quote Link to comment Share on other sites More sharing options...
abraxus Posted September 26, 2013 Share Posted September 26, 2013 i am not aware of any such function besides IntersectWith- so if they do not intersect, you will have to combine IntersectWith with code extra code define a point on the line, and then programatically draw another line from that point at 0 degrees and at the distance you want to detect then use that new line and create a polar array from the original point every 5 degrees around that point using that line now you have an array of lines which you can use to iterate thru using the IntersectWith function to detect any intersections hope that helps edit: i have attached a file that visually demonstrates my idea IntersectWith.dwg Quote Link to comment Share on other sites More sharing options...
KoenE Posted September 27, 2013 Author Share Posted September 27, 2013 So Abraxus or anyone interrested, My following question: How do I add one of those lines newly created lines plus the line I'm trying to find to my selectionset. Because I neew both lik this: LineJustCreated.IntersectWith(lineToFind, acExtendnone) Am I in the right direction? Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 27, 2013 Share Posted September 27, 2013 Is it safe to say the object is always linear? Circle, Ellipse, Spline entities would certainly complicate matters. Not to mention Polylines and Block Inserts. Also, Is the entity coplanar with the WCS (i.e.,dealing with just 2D geometry)? Quote Link to comment Share on other sites More sharing options...
KoenE Posted September 27, 2013 Author Share Posted September 27, 2013 SEANT Is it safe to say the object is always linear? Circle, Ellipse, Spline entities would certainly complicate matters. Not to mention Polylines and Block Inserts. Also, Is the entity coplanar with the WCS (i.e.,dealing with just 2D geometry)? Well, the drawing is 2D and I am only looking for lines, so hooray! Only the lines are often polylines, I just don't understand why this makes things complicated... Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 27, 2013 Share Posted September 27, 2013 Well, the drawing is 2D and I am only looking for lines, so hooray! Only the lines are often polylines, I just don't understand why this makes things complicated... [/indent] A line/line comparison only has to test the two endpoints of the "Test line" to the "Primary line". Polylines have more end points (Vertices) to test - as well as the potential for Arcs. Quote Link to comment Share on other sites More sharing options...
KoenE Posted September 27, 2013 Author Share Posted September 27, 2013 @SEANT Ah, I see. It is certain that the polylines do not consist of arcs, also the function to get all vertex and their coördinates of the polyline is already running. But the problem right now remains, I dont know how to select a line within a certain range of a other line, even if I were to use InterectWith, I still need to add the line to my selectionset.. Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 27, 2013 Share Posted September 27, 2013 An alternate method of testing a point (PT) against a “PrimaryLine”: Get the SlopeVector of the line via PrimaryLine.Delta. Create a PerpendicularVector Dim PerpendicularVector (0 To 2) As Double PerpendicularVector(0) = - SlopeVector(1) ‘note the negative sign PerpendicularVector(1) = SlopeVector(0) PerpendicularVector(2) = 0.0 Then create a second point based on that vector and the testing point (PT) Dim SecondPoint (0 To 2) As Double SecondPoint(0) = PT(0) + PerpendicularVector(0) SecondPoint(1) = PT(1) + PerpendicularVector(1) SecondPoint(2) = PT(2) + PerpendicularVector(2) Then create a Xline using the PT and SecondPoint. Finally, call intersectWith using the PrimaryLine and Xline. Further testing may be needed if there is no intersection. Quote Link to comment Share on other sites More sharing options...
abraxus Posted October 2, 2013 Share Posted October 2, 2013 i made some adjustments to my CollisionDetect code today that made it much faster, and it relates to this topic as well First off, keep in mind that trying to find other objects "near" a line gets very complex, because even a line with endpoints has a variable length, so it all depends on how you define "near" in that case instead, you will need to define a point on the line that you want to find something "near" to once you define that point (as kinda shown in my example from a few days ago) you can create a selection set of objects based on a thresh-hold value - kinda like a radius, but since you will have to use "window" or "crossing" to select any fixtures near it, it would be more like a square radius instead of circular then once you have all that information, you iterate thru the selection set and compare something about those entities with the given point you want to find it "near" to... you can probably use a bounding box to define min and max values for x and y of the selection set based on the endpoints of the line (that's simple to do) but keep in mind that that larger the selection set you have to process is, the longer it's going to take and keep in mind that any code that takes longer than about 2 seconds to run should really have a progress bar form that shows up (with doevents in the loop) so the user doesnt think that their computer has locked up by executing your code Quote Link to comment Share on other sites More sharing options...
KoenE Posted October 2, 2013 Author Share Posted October 2, 2013 Thanks abraxus, I am currently trying out an other way to do what i want. But also working on a project wich must be finished by the end of the week. It's a shame because I could use this code to speed things up, now I have to work the old fashioned way for a bit longer... Quote Link to comment Share on other sites More sharing options...
abraxus Posted October 4, 2013 Share Posted October 4, 2013 here's another approach: using your line, create a bounding box, then add some padding to it, and build a selection set using the points you create based on a crossing selection on those bounding box points, and then process that selection set Quote Link to comment Share on other sites More sharing options...
abraxus Posted October 4, 2013 Share Posted October 4, 2013 get the bounding box for the line, then add a tolerance variable to it to define a crossing for a programmatic selection set to process Quote Link to comment Share on other sites More sharing options...
fixo Posted October 6, 2013 Share Posted October 6, 2013 Thanks abraxus, I am currently trying out an other way to do what i want. But also working on a project wich must be finished by the end of the week. It's a shame because I could use this code to speed things up, now I have to work the old fashioned way for a bit longer... Not sure about if this helps try this one from my oldies, this will allow you to search for nearest text to a line, change the selection filter to your needs: Option Explicit Const pi As Double = 3.14159265358979 Public Sub TouchNearestText() Dim oEnt As AcadEntity Dim oLine As AcadLine Dim pickPt On Error GoTo Err_Report Call ThisDrawing.Utility.GetEntity(oEnt, pickPt, vbLf & "Select a Line: ") If Not TypeOf oEnt Is AcadLine Then MsgBox "Not a Line!" Exit Sub End If Set oLine = oEnt Dim minExt As Variant Dim maxExt As Variant ' Return the bounding box for the line and return the minimum ' and maximum extents of the box in the minExt and maxExt variables. oLine.GetBoundingBox minExt, maxExt Dim pts(0 To 11) As Double pts(0) = minExt(0): pts(1) = minExt(1): pts(2) = 0# pts(3) = maxExt(0): pts(4) = minExt(1): pts(5) = 0# pts(6) = maxExt(0): pts(7) = maxExt(1): pts( = 0# pts(9) = minExt(0): pts(10) = maxExt(1): pts(11) = 0# Dim setObj As AcadSelectionSet Dim setColl As AcadSelectionSets Dim oText As AcadText Dim pickPnt As Variant Dim setName As String Dim selMod As Long Dim vertPts As Variant Dim dblElv As Double Dim gpCode(1) As Integer Dim dataValue(1) As Variant Dim dxfcode, dxfdata '' build your filter here: gpCode(0) = 0: gpCode(1) = 8 dataValue(0) = "TEXT": dataValue(1) = "0" dxfcode = gpCode: dxfdata = dataValue setName = "$CrossSelect$" With ThisDrawing Set setColl = .SelectionSets For Each setObj In setColl If setObj.Name = setName Then .SelectionSets.item(setName).Delete Exit For End If Next Set setObj = .SelectionSets.Add(setName) End With selMod = AcSelect.acSelectionSetCrossingPolygon ' <-- can use also acSelectionSetWindowPolygon ' setObj.SelectByPolygon selMod, pts, dxfcode, dxfdata setObj.Highlight True Dim objEnt As AcadEntity Dim dblDist As Double If setObj.Count = 0 Then Exit Sub Dim distArr As Variant Dim ang As Double Dim angLine As Double ReDim arr(1000, 1) As Variant ''put maximum number of nearer items you need ' >> do your stuffs here Dim n For Each objEnt In setObj Set oText = objEnt Dim ptIns As Variant ptIns = oText.InsertionPoint angLine = oLine.Angle ang = ThisDrawing.Utility.AngleFromXAxis(oLine.StartPoint, ptIns) ang = ang - angLine dblDist = Distance(ptIns, oLine.StartPoint) dblDist = Abs(dblDist * Sin(ang)) arr(n, 0) = oText.Handle: arr(n, 1) = dblDist n = n + 1 Next Dim strHandle As String Dim minDist minDist = arr(0, 1) For n = 0 To UBound(arr, 1) If arr(n, 0) <> "" And arr(n, 1) < minDist Then minDist = arr(n, 1) strHandle = arr(n, 0) End If Next '' change some properties of a text you've found Set objEnt = ThisDrawing.HandleToObject(strHandle) objEnt.Layer = oLine.Layer objEnt.TrueColor = oLine.TrueColor objEnt.Update MsgBox "Minimum distance: " & minDist Err_Report: If Err.Number <> 0 Then MsgBox Err.Description End If End Sub '' by Bryco Public Function Distance(ByVal pt1 As Variant, ByVal pt2 As Variant) As Double Dim x As Double, y As Double, z As Double Dim dist As Double ' Calculate the distance between pt1 and pt2 x = pt1(0) - pt2(0) y = pt1(1) - pt2(1) z = pt1(2) - pt2(2) dist = Sqr((Sqr((x ^ 2) + (y ^ 2)) ^ 2) + (z ^ 2)) Distance = dist End Function Quote Link to comment Share on other sites More sharing options...
fixo Posted October 6, 2013 Share Posted October 6, 2013 Here is more readable source code, see attached: FindNearestObject.txt Quote Link to comment Share on other sites More sharing options...
