bkrupp Posted September 20, 2013 Posted September 20, 2013 How do you use (or is it proper to use) the Fan In option when all the wires being represented by that bundle are coming from multiple sheets? For example, the machine being designed needs one 8 core wire going from the main cabinet to the HMI cabinet (for I/O and low voltage power). The source wires for the Fan In are spread across two sheets in Autocad Electrical and the Destination wires are also spread across several sheets. How can I illustrate that wires from these multiple pages are all part of the same multi-core wire going from one location to another? Quote
