I'm struggling to create an MLeader object with MText:
\LCONSTRUCTION NOTE:\l\P[ATTRIBUTE]
I wish to:
1) use command "ATTOUT" to create a text file "[drawing]ATTOUT.txt" in the drawing folder (in Windows Explorer) containing a seperate block named "POINT" with attribute [POINT] and MLeader(or block) named "CNOTE" with attribute [CNOTE],
2) change [CNOTE] value for all [POINT] values in Excel workbook,
3) save Excel workbook to (Tab-delimited) "[drawing]ATTIN.txt" in the same drawing folder (in Windows Explorer),
4) use command "ATTIN" to change [ATTRIBUTE] and [POINT] values.
I'm running AutoCAD 2014 Map3D, Windows 7, and Excel 2010.
Thank you for any advice or routines to make this possible!
