Hi Everyone,
I just upgraded to autocad 2014 so far everything has been running smoothly only only problem so far is I am not able to modify an existing wall that was drawn in the previous version. See attachment. Anyone has any idea as to why this is?
http://i.imgur.com/kLVjydX.png
Thanks.
EDIT 1: I just noticed that I can't draw the wall either. Previously I could go the tool palette or go into draw and draw some walls, now I don't see that option anywhere.
Edited by dahabit
Looks to me like you're in the plain AutoCAD profile. Make sure you're in the AutoCAD Architecture profile. You must start the program from the Architecture Profile, you cannot open AutoCAD then switch to the Architecture Profile - the AEC Tools only load when you start the program in the correct Profile.
Thank you, it worked.
