coordinate point list (*.txt file) and table
I add this comand but nothing
(setq hgt (getreal "\n Specify text height "))
  • Replies 24
  • Lee Mac
    6
  • MSasu
    4
  • shailujp
    2
  • Tuns
    1
Posted Images
My suggested work-around was to use the built-in command to set the preferred height for table's labels prior to call Lee Mac’s routine.
Although the code you written is correct, if you want to modify Lee’s code, then will need to adjust more then to prompt for height.
Prodromosm, I suggested you a work-around using table preferences. Isn't that enough to achive what you want?
Check.... if you wont get then come back me
