The link is no good.
What's so special about the annotation that appears as an image in your post? My guess is it is either a block or a dynamic block.
Thanks ReMark for the reply.
... and as a beginner 'the annotation that appears as an image in my post is so special' for me... that's why I posted this thread in the AutoCAD Beginners' Area.
I would assume it's an annotative block. They're not hard to make really. There are tutorials online all over the place for annotative blocks.
Thanks Tuns ... I thought there would be some inbuilt stuff like the 'Leaders'.
I wanted to know if it was a regular block or a dynamic block.
Assuming you are asking about GD&T, if not ignore. You can use TOLERANCE command for the M and for the other frames, the line and rectangle will be made by you. Draw it and create a block.
Multileader would be a good way to go, pretty easy to get set up.
