marbile Posted September 11, 2013 Share Posted September 11, 2013 I am migrating from Autocad Map 2009 in windows XP (32 bits), to Map 2014 64bits, in Windows 7 64 bits My question is if is possible to use visual basic 6.0 activex with Map 2014 64bits And if it is possible, what to do to get the interface to it. I have from history a "dll Visual Basic 6.0 Activex Com module", which I use to connect from visual lisp, through vla-GetInterfaceObject" call. It works fine in Autocad Map 2009 with XP I recompile it using the correct libraries from Map 2014, and registered with regsvr32 (just in case, I also registered with the regsvr32 that is in windows/SysWow64/regsvr32) But I received an "Automation Error. Problem in loading application" error message, when doing: (vla-GetInterfaceObject (vlax-get-acad-object) "marVBasic.marVbUtils") Being marVBasic the name of the visual basic proyect, and marVbUtils the class. (This works fine in Map 2009) Thks Quote Link to comment Share on other sites More sharing options...
