tphilp Posted September 9, 2013 Posted September 9, 2013 Hi all, CADtutor newbie here. I am partner in a small solar energy consulting company and we are looking for a program that will produce relatively accurate layouts for building roof tops for our solar arrays. We would want to import PDFs, or maybe JPEFs. Previously we have worked with engineers that used AutoCAD with good results. I was looking at AutoSketch, but it runs $260 or so, and we would need two or three copies. I followed a thread about DraftSight that lead me to this web site, hoping for some input from you AutoCAD experts. Is there a good share ware program out there? Quote
stevsmith Posted September 10, 2013 Posted September 10, 2013 For free, Draftsight is as good as you will get. My company uses it along side Solidworks because we would grudge paying for AutoCad. It's never a good thing to import PDF's and jpegs to be honest, its a nightmare re-scaling them, but that's just my opinion. Plenty of people still do it to good (or goodish) effect. Other options would be Briscad and TurboCAD. There are a few others that the other users would recommend, but these are the ones I'm mostly aware of. Oh, and welcome to the forums. Quote
Cad64 Posted September 10, 2013 Posted September 10, 2013 I used Draftsight for about 6 months, before I decided to purchase a copy of ProgeCad. Draftsight is a good 2D drafting program, and as stevsmith said, it's about as good as you're going to get for free. I switched to ProgeCad because I needed 3D capability, Express Tools and I wanted to be able to use my lisp routines. I would recommend that you download and try Draftsight for yourself, but if you find you need something a little more powerful, take a look at ProgeCad, Bricscad or Turbocad. They are all low cost alternatives to Autocad. Quote
welldriller Posted September 10, 2013 Posted September 10, 2013 You might check this out here on the forum Free CAD programs for the non-student. Started by ReMark, 27th Feb 2013 06:24 am Quote
tphilp Posted September 10, 2013 Author Posted September 10, 2013 thanks for your fast responses! I will look at your recommendations and see how it all works. Hopefully our tiny company will go and I can afford full autoCAD, I will be back here full time. Great forum. Quote
tphilp Posted September 10, 2013 Author Posted September 10, 2013 By the way, I assume that AutoSketch is compatible (more or less) with AutoCAD, templates, commands? Am I looking too short sighted to be considering Draftsight, assumming that I might have to transition to something more powerful eventually? Just looking for opinions, perspectives. Thanks Quote
ReMark Posted September 10, 2013 Posted September 10, 2013 So you don't want free you want low cost? See my other thread re: Low cost CAD programs. http://www.cadtutor.net/forum/showthread.php?77642-Low-cost-CAD-programs.&highlight=progecad Quote
f700es Posted September 10, 2013 Posted September 10, 2013 By the way, I assume that AutoSketch is compatible (more or less) with AutoCAD, templates, commands? I would have to say "No". I would call AutoSketch a MS Visio like program that AutoDesk bought many years ago. It acts nothing like AutoCAD and is completely different. The last version of AutoSketch was released in 2008. So I would consider it dead. Am I looking too short sighted to be considering Draftsight, assumming that I might have to transition to something more powerful eventually? Just looking for opinions, perspectives. Thanks DraftSight will look and feel like an older version of AutoCAD LT. Many of the commands are the same. Similar layout with some differences here and there, espically in the Options area. The best way to see is to simply download, install and give it a try. Quote
tphilp Posted September 10, 2013 Author Posted September 10, 2013 is there any way to import PDFs to Draftsight? I have clients that give me information in that format and it would be easier than redrawing the whole building. Quote
ReMark Posted September 10, 2013 Posted September 10, 2013 You would have to use the ATTACHIMAGE command to bring the PDF into Draftsight then you would have to trace over it. After tracing over it you could scale it using the reference option. I'm not sure if this would be accurate enough for what you are doing. Quote
tphilp Posted September 10, 2013 Author Posted September 10, 2013 Do you know of any programs that would allow me to import PDFs? Quote
f700es Posted September 10, 2013 Posted September 10, 2013 There are ways to get around this. There are several on-line services that will convert them for you for free. Here is one I tried and the file I got back was just as good visually as any other PDF-to-DWG. http://dwg.autodwg.com/ I used my Yahoo.com e-mail in case of spam. Quote
ReMark Posted September 10, 2013 Posted September 10, 2013 Just as good visually? What exactly does that mean when it comes time to edit the geometry? Are we saying "it's close enough for government work?" LoL Quote
f700es Posted September 10, 2013 Posted September 10, 2013 Looked as good as Adobe Illustrator did in the conversion. Let me do a full comparison. Quote
tphilp Posted September 10, 2013 Author Posted September 10, 2013 any experience/comments on DoubleCAD XT? Quote
f700es Posted September 10, 2013 Posted September 10, 2013 OK here we go... The left file is from the online service and the right from Adobe Illustrator. Both are fair conversions with the online file being a bit smaller in file size. 572kb compared to 762kb. Both seemed to have converted text into hatches. They are what they are, converted PDFs into DWG and a user should take these with a grain of salt and use accordingly. Quote
f700es Posted September 10, 2013 Posted September 10, 2013 any experience/comments on DoubleCAD XT? It's usable but I found DraftSight to be closer to what I was used to in AutoCAD. Quote
ReMark Posted September 10, 2013 Posted September 10, 2013 The OP's criteria: "...to produce relatively accurate layouts for building roof tops for our solar arrays." I guess that method would be close enough to work then. Quote
f700es Posted September 10, 2013 Posted September 10, 2013 Only the OP can make that determination based on his assessments. Through my experiences I know when and where I can use a converted PDF and make it work and when I can't. Quote
