Vray sun gives strange colors in rendering
ShivaRoma
Hi everybody
I have already read and understood vray guide on sun and sky but here I get a very strange color when rendering.I tried changing size and distance and multiplier,still cant get a nice sunny day light.Any suggestions?
try to use a Daylight (command pannel>> create >> systems)
after setting, on the viewport select the Light Source and go to the the modifier panel
then
set VraySun as the sunlight. Press Yes for the effects so to automatically let it set the skylight, and after that you will need to set the Skylight to none. just below the sunlight in the modifications.
this system simulates real world coloring of sky and sun light. so according to the time you set, it will change the color of sky as well.
if you get blown light image press 8 and choose vray exposure and go on...
P.S. this system is a GI based, so in rendering setup, have your GI enabled !
