chraibi Posted October 2, 2010 Share Posted October 2, 2010 (edited) Works like a charm!! Many many thanks! For learning purposes what does the following line do: (LM : DXF->Variants (list (cons 8 (LM:lst->str (_LayerList doc) ","))) 'typ 'val) I guesse here is the content in the dwg-file saved: (if (not (zerop (vla-get-Count ss))) (vla-WBlock doc file ss)) right? If I change the suffix "dwg" in "dxf" setq file (getfiled "Create Output File" "" "dwg" 1)) Would I get a dxf-file as a result? Edited October 2, 2010 by chraibi space between : and D Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 2, 2010 Share Posted October 2, 2010 Works like a charm!! Many many thanks! Excellent, good to hear. For learning purposes what does the following line do: (LM : DXF->Variants (list (cons 8 (LM:lst->str (_LayerList doc) ","))) 'typ 'val) Creates two variants - one of integer type and one of variant type to house the data for the selection set filter. I guesse here is the content in the dwg-file saved: (if (not (zerop (vla-get-Count ss))) (vla-WBlock doc file ss)) right? If I change the suffix "dwg" in "dxf" setq file (getfiled "Create Output File" "" "dwg" 1)) Would I get a dxf-file as a result? I haven't tried, but yes, that is where you would change it. Lee Quote Link to comment Share on other sites More sharing options...
chraibi Posted October 2, 2010 Share Posted October 2, 2010 Unfortunately it does not work! I googled a little and found this hint: write: (setenv"DefaultFormatForSave""13") bevor: (if (not (zerop (vla-get-Count ss))) (vla-WBlock doc file ss)) Look at the DefaultFormatForSave environment variable (getenv/setenv functions) the values are : "48" -> dwg 2010 "36" -> dwg 2007 "24" -> dwg 2004 "12" -> dwg 2000 "8" -> dwg R14 "38" -> dwt "37" -> dxf 2007 "25" -> dxf 2004 "13" -> dxf 2000 "1" -> dxf R12 But this fails too! :-( Mybe another Idea? Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 12, 2010 Share Posted October 12, 2010 Thanks Lee, both works OK for me. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 12, 2010 Share Posted October 12, 2010 You're very welcome MDBDesign Quote Link to comment Share on other sites More sharing options...
chraibi Posted October 13, 2010 Share Posted October 13, 2010 Lee Mac: I don't know why I can not send you a pm. But do you mind if I publish your code, that you helped me with, on my private homepage? Of corse with a link to yours or to the discussion here. Quote Link to comment Share on other sites More sharing options...
Tiger Posted October 13, 2010 Share Posted October 13, 2010 Lee Mac: I don't know why I can not send you a pm. But do you mind if I publish your code, that you helped me with, on my private homepage? Of corse with a link to yours or to the discussion here. OU! OU! *waves hand* I know! I know! You can't use the PM-system til you have 10 posts under your belt. This is to prevent spamming mostly. Oh, and in the future, please start a new thread for each new question. I realise that this question is based on the old question, but it confuses things to have a thread form 2006 pop up again. Quote Link to comment Share on other sites More sharing options...
chraibi Posted October 13, 2010 Share Posted October 13, 2010 Sure! This was impolite from me. I apologize! Quote Link to comment Share on other sites More sharing options...
Tiger Posted October 13, 2010 Share Posted October 13, 2010 Sure! This was impolite from me. I apologize! Don't worry, now you know Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 13, 2010 Share Posted October 13, 2010 Lee Mac: I don't know why I can not send you a pm. But do you mind if I publish your code, that you helped me with, on my private homepage? Of corse with a link to yours or to the discussion here. Hi Chraibi, Certainly, providing all headers remain in tact I feel honoured to have my code feature elsewhere on the web Lee Quote Link to comment Share on other sites More sharing options...
shennig Posted December 9, 2011 Share Posted December 9, 2011 Try to use. Look at comments! ;| Limitations: file sould be opened "full" (not partial). All layers should be thawed, on, unlocked (not controlled). Layout entities will create unexpected result - be careful! Actually there are some ways to change code to select only model entites But i can't do it - i've got too much job And something else - look how the code works * written by kpblc 2006 Nov 23 |; (defun c:lay2file (/ adoc selset) (vl-load-com) (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))) ) ;_ end of vla-StartUndoMark (vlax-for ss (vla-get-selectionsets adoc) (if (= (vla-get-name ss) "temp") (progn (vla-clear ss) (vla-erase ss) ) ;_ end of progn ) ;_ end of if ) ;_ end of vlax-for (setq selset (vla-add (vla-get-selectionsets adoc) "temp")) (vlax-for lay (vla-get-layers adoc) (if (and (not (vla-select selset acselectionsetall (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble '(0 . 0) ) ;_ end of vlax-make-safearray '( ) ;_ end of vlax-safearray-fill ) ;_ end of vlax-make-variant (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbvariant '(0 . 0) ) ;_ end of vlax-make-safearray (list (vla-get-name lay)) ) ;_ end of vlax-safearray-fill ) ;_ end of vlax-make-variant ) ;_ end of vla-select ) ;_ end of not (> (vla-get-count selset) 0) ) ;_ end of and (vla-wblock adoc (strcat (getvar "dwgprefix") (vla-get-name lay) ".dwg") selset ) ;_ end of vla-Wblock ) ;_ end of if (vla-clear selset) ) ;_ end of vlax-for (vl-catch-all-apply '(lambda () (vla-delete selset))) (vla-endundomark adoc) (princ) ) ;_ end of defun At VBA code could be more readable. this works great....but i was hoping to have the file name as a prefix on the front of the created file before the layer name.can you please tell me where & what to input i have tried several areas but have failed Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 9, 2011 Share Posted December 9, 2011 Here is my version: [color=GREEN];; Layers to Drawings - Lee Mac - 2011 - www.lee-mac.com[/color] [color=GREEN];; WBlocks objects on each layer in a drawing to separate drawing files.[/color] ([color=BLUE]defun[/color] c:lay2dwg ( [color=BLUE]/[/color] _UniqueFilename acdoc acsel fpath typevar ) ([color=BLUE]defun[/color] _UniqueFilename ( seed [color=BLUE]/[/color] f i ) ([color=BLUE]setq[/color] i 1) ([color=BLUE]if[/color] ([color=BLUE]findfile[/color] ([color=BLUE]setq[/color] f ([color=BLUE]strcat[/color] seed [color=MAROON]".dwg"[/color]))) ([color=BLUE]while[/color] ([color=BLUE]findfile[/color] ([color=BLUE]setq[/color] f ([color=BLUE]strcat[/color] seed [color=MAROON]"("[/color] ([color=BLUE]itoa[/color] ([color=BLUE]setq[/color] i ([color=BLUE]1+[/color] i))) [color=MAROON]").dwg"[/color])))) ) f ) ([color=BLUE]defun[/color] _UniqueItem ( collection seed [color=BLUE]/[/color] i ) ([color=BLUE]setq[/color] i 1) ([color=BLUE]while[/color] ([color=BLUE]null[/color] ([color=BLUE]vl-catch-all-error-p[/color] ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vla-item[/color] ([color=BLUE]list[/color] collection ([color=BLUE]strcat[/color] seed ([color=BLUE]itoa[/color] ([color=BLUE]setq[/color] i ([color=BLUE]1+[/color] i))))) ) ) ) ) ([color=BLUE]strcat[/color] seed ([color=BLUE]itoa[/color] i)) ) ([color=BLUE]setq[/color] acdoc ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color])) acsel ([color=BLUE]vla-get-selectionsets[/color] acdoc) acsel ([color=BLUE]vla-add[/color] acsel (_UniqueItem acsel [color=MAROON]"lay2dwg"[/color])) fpath ([color=BLUE]strcat[/color] ([color=BLUE]getvar[/color] 'DWGPREFIX) ([color=BLUE]cadr[/color] ([color=BLUE]fnsplitl[/color] ([color=BLUE]getvar[/color] 'DWGNAME))) [color=MAROON]"_"[/color]) ) ([color=BLUE]vla-clear[/color] acsel) ([color=BLUE]setq[/color] typevar ([color=BLUE]vlax-make-variant[/color] ([color=BLUE]vlax-safearray-fill[/color] ([color=BLUE]vlax-make-safearray[/color] [color=BLUE]vlax-vbinteger[/color] '(0 . 1)) '(8 410) ) ) ) ([color=BLUE]vlax-for[/color] layer ([color=BLUE]vla-get-layers[/color] acdoc) ([color=BLUE]vla-select[/color] acsel [color=BLUE]acselectionsetall[/color] [color=BLUE]nil[/color] [color=BLUE]nil[/color] typevar ([color=BLUE]vlax-make-variant[/color] ([color=BLUE]vlax-safearray-fill[/color] ([color=BLUE]vlax-make-safearray[/color] [color=BLUE]vlax-vbvariant[/color] '(0 . 1)) ([color=BLUE]list[/color] ([color=BLUE]vla-get-name[/color] layer) [color=MAROON]"Model"[/color]) ) ) ) ([color=BLUE]if[/color] ([color=BLUE]<[/color] 0 ([color=BLUE]vla-get-count[/color] acsel)) ([color=BLUE]progn[/color] ([color=BLUE]vla-wblock[/color] acdoc (_UniqueFilename ([color=BLUE]strcat[/color] fpath ([color=BLUE]vla-get-name[/color] layer))) acsel) ([color=BLUE]vla-clear[/color] acsel) ) ) ) ([color=BLUE]vla-delete[/color] acsel) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Another alternative here. Quote Link to comment Share on other sites More sharing options...
shennig Posted December 11, 2011 Share Posted December 11, 2011 thanks lee that is exactly what i was after Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 11, 2011 Share Posted December 11, 2011 You're welcome shennig Quote Link to comment Share on other sites More sharing options...
anbard Posted January 16, 2014 Share Posted January 16, 2014 (edited) Hello all, I have found the Autocad_Script.lsp to be a great help to me, but I was wondering how this could be modified to save each layer in an earlier version of AutoCAD i.e 2000 or R14. Any assistance would be appreciated. John (defun c:lsave(/ actDoc layCol docName dwgName actSel fCount) (vl-load-com) (defun BrowseFolder (/ ShlObj Folder FldObj OutVal) (vl-load-com) (setq ShlObj (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application" ) Folder(vlax-invoke-method ShlObj 'BrowseForFolder 0 "Select Folder to create files" 0) ) (vlax-release-object ShlObj) (if Folder (progn (setq FldObj (vlax-get-property Folder 'Self) OutVal (vlax-get-property FldObj 'Path) ) (vlax-release-object Folder) (vlax-release-object FldObj) OutVal ) ) ) (setq actDoc(vla-get-ActiveDocument (vlax-get-acad-object)) actSel(vla-get-ActiveSelectionSet actDoc) layCol(vla-get-Layers actDoc) docName(vla-get-Name actDoc) fCount 0 ); end setq (if (setq wntPath (BrowseFolder)) (progn (vlax-for lay layCol (setq layName(vla-get-Name lay) dwgName (strcat wntPath "\\" (vl-filename-base docName) " - " layName ".dwg") ); end setq (vla-clear actSel)(vla-erase actSel) (vla-Select actSel acSelectionSetAll nil nil (vlax-safearray-fill (vlax-make-safearray vlax-vbInteger '(0 . 0)) '( ) ; end vla-safearray-fill (vlax-safearray-fill (vlax-make-safearray vlax-vbvariant '(0 . 0)) (list layName) ) ; end vla-safearray-fill ) ; end vla-select (if(/= 0(vla-get-Count actSel)) (vla-WBlock actDoc dwgName actSel)); end if (setq fCount(1+ fCount)) ); end vlax-for ); end progn ); end if (princ (strcat "\*** " (itoa fCount) " files were created *** ")) (princ) ); end of c:lsave Edited January 16, 2014 by anbard wrap code Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 16, 2014 Share Posted January 16, 2014 Please read the Code posting guidelines and edit your post to include the Code in Code Tags. Quote Link to comment Share on other sites More sharing options...
kpblc Posted January 16, 2014 Share Posted January 16, 2014 ...how this could be modified to save each layer in an earlier version of AutoCAD i.e 2000 or R14... I think it's impossible. Code uses vla-wblock function. This function can save dwg only at native format. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted January 16, 2014 Share Posted January 16, 2014 You can change temporary "save as:" in Tools>Options>Open and Save, to version you need. Quote Link to comment Share on other sites More sharing options...
anbard Posted January 16, 2014 Share Posted January 16, 2014 Thanks for relying! If it's impossible then the other option is to open the files and saveas version required as suggested, I started this today. If there is a batch way of doing this I'm open to suggestion but limited in programming skills! Willing to learn but just need direction! Many thanks again, John Quote Link to comment Share on other sites More sharing options...
kpblc Posted January 16, 2014 Share Posted January 16, 2014 > mdbdesign : I think this step won't change vla-wblock functionality. As i know this function use ObjectDBX mechanism. Quote Link to comment Share on other sites More sharing options...
