Einsuner29 Posted September 3, 2013 Posted September 3, 2013 Hello! I'm using annotative scales. But for example line type scale will also change when I change annotative scale. How can I turn that off. Cheers! M Quote
Dadgad Posted September 3, 2013 Posted September 3, 2013 I don't know much about annotative scales, don't use them. However, look at the attached image, and see if that might be the variable you are after. I think you have SYSVDLG in 2008, if so that is a good place to search for the variable, if this isn't the one. Quote
Einsuner29 Posted September 3, 2013 Author Posted September 3, 2013 I think i'm looking for property that turns off annotative property of lines. M Quote
ReMark Posted September 3, 2013 Posted September 3, 2013 Annotative scaling was introduced in AutoCAD 2008. Annotative objects include text, dimensions, blocks and hatches. Linetype scale is independent of annotative scaling. Quote
ReMark Posted September 3, 2013 Posted September 3, 2013 Note that 'linetypes' does not appear. Quote
RobDraw Posted September 3, 2013 Posted September 3, 2013 Linetype scale, although it is a separate setting, is affected by annotative scale. The appearance of linetypes changes according to scale. It does that so that the same linetype looks the same on paper at any scale. I don't think there is a way to not have it change when changing scales. You may want top look into working through viewports and the VPMax command. I understand your question but if you explain why you would like to do what you are asking, we may be able to help. Quote
Einsuner29 Posted September 3, 2013 Author Posted September 3, 2013 I would attach dwg file, but i can't find how. M Quote
RobDraw Posted September 3, 2013 Posted September 3, 2013 There is no need to attach a file. Just explain your situation in a little more detail. If you think it will help, click on "Go Advanced" on this page and then go to the manage attachments section. Quote
Einsuner29 Posted September 3, 2013 Author Posted September 3, 2013 line scale.dwg OK, if ya change other annotative scale and regen drawing you will see the difference. I hope Quote
RobDraw Posted September 3, 2013 Posted September 3, 2013 Yes, that is the way annotative scaling works. Please read post #6 again, carefully. I'm sensing a disconnect in our conversation. Is English not your first language? Quote
Einsuner29 Posted September 3, 2013 Author Posted September 3, 2013 Ok, i suppose i have to look over my working process and modify it abit Quote
Einsuner29 Posted September 3, 2013 Author Posted September 3, 2013 OK, i have to modify my work proccess then Quote
