Hello,
when clicking on any object in AutoCAD 2014, I see always the same values in the Properties Window. No matter what I create or what I click on, I only see the same exact numbers which do not change at all. Have you ever had the same problem? Did you find a solution?
Thank you very much for your help.
  • 1 month later...
Thank you very much, it has finally worked.
