Tereza Posted September 2, 2013 Posted September 2, 2013 Hello, when clicking on any object in AutoCAD 2014, I see always the same values in the Properties Window. No matter what I create or what I click on, I only see the same exact numbers which do not change at all. Have you ever had the same problem? Did you find a solution? Thank you very much for your help. Quote
nestly Posted September 2, 2013 Posted September 2, 2013 Sounds like you either used a registry cleaner... http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8227659&linkID=9240617 or uninstalled autodesk360, both have been known to cause the properties palette to stop displaying selected objects. Quote
Tereza Posted October 4, 2013 Author Posted October 4, 2013 Thank you very much, it has finally worked. Quote
