andar424 Posted August 28, 2013 Posted August 28, 2013 I've seen it before, but can't seem to find it. Where do I want to start if I'm wanting to write a rule that every time I save, Inventor will export to pdf (in the case of drawings). I'm completely new to rules, and any help would be appreciated! TIA! Quote
andar424 Posted August 28, 2013 Author Posted August 28, 2013 Never mind, found this on youtube. Quote
andar424 Posted August 28, 2013 Author Posted August 28, 2013 Does anyone know where you can mess with the settings/options of the pdf export when using iLogic rules? For instance, when you just use the export tool, you can make a pdf with object line weights turned off. I'd like to have that in the rule. Quote
