I've seen it before, but can't seem to find it. Where do I want to start if I'm wanting to write a rule that every time I save, Inventor will export to pdf (in the case of drawings). I'm completely new to rules, and any help would be appreciated!
TIA!
Never mind, found this on youtube.
Does anyone know where you can mess with the settings/options of the pdf export when using iLogic rules? For instance, when you just use the export tool, you can make a pdf with object line weights turned off. I'd like to have that in the rule.
