PEGAdevelopment Posted August 22, 2013 Share Posted August 22, 2013 I am having some trouble with the intersection tool. The results are never what is intended. Is there a way to create the intersection manually? I tried pasting both primary and secondary road corridor surfaces into a new surface, then used feature lines to connect the curbs on the returns. Then I added those to the new surface as breaklines. The results were just as hideous. Any help would be appreciated, thanks. Quote Link to comment Share on other sites More sharing options...
Bill_Myron Posted August 22, 2013 Share Posted August 22, 2013 This is the way we used to do it before Intersections. A bunch of Alignments, Profiles, Feature Lines, and Corridors. http://civilforautocad.blogspot.ca/2009/03/pre-2010-intersection-design-with-civil.html Quote Link to comment Share on other sites More sharing options...
Organic Posted August 23, 2013 Share Posted August 23, 2013 This is the way we used to do it before Intersections. A bunch of Alignments, Profiles, Feature Lines, and Corridors. http://civilforautocad.blogspot.ca/2009/03/pre-2010-intersection-design-with-civil.html Used too? That is how most roads still are modeled, regardless of whether it it Civil 3D or other civil software. Quote Link to comment Share on other sites More sharing options...
PEGAdevelopment Posted August 23, 2013 Author Share Posted August 23, 2013 Thanks, Bill. That really helped. Although I'm still struggling a bit. This is like an art lol. Quote Link to comment Share on other sites More sharing options...
JerryG Posted September 26, 2013 Share Posted September 26, 2013 It takes a bit to get used to the Intersections and what Assembly goes where etc but once you get used to it creating intersections goes pretty fast. I've found that labeling your assembly's correctly helps allot. Also a key factor is how you create the original Alignment. Make sure is is Perpendicular with the Main road Alignment at its ending point if its just a 3 way Intersection. Also remember that the Alignment Stationing will follow from 0+00 from the Main Road to your intersecting road on the SW corner and from 0+00 to the main road on the SE corner. So when picking your Assembly you have to think about what direction the Alignment is going. Hope that helps and didn't just make it more confusing:D Quote Link to comment Share on other sites More sharing options...
