Hi to all,
So, this is my lisp. It does the following:
1) Adds revision clouds to multiple entities
2) Adds Layer (or create if required and add properties)
3) Adds hatch
4) Inserts a block for leader and text (already formated)
I have very limited knowledge of the lisp. As you can see I have copied few different codes and combined it to make it work for my application. It works but I know this is not systematic at all. I dont know if my error handeling is correct.
One thing that I wish to add is if the revision cloud is too big or too small, it should allow to do that without closing and undoing everything. In other sense, I need undo and reset arc length option in this. Can someone help me on this please?
(defun c:RVC6 (/ *error* oce mflag ans)
;************************************Error handling*********************************************
  (defun *error* (msg)
    (setvar "cmdecho" OCE)
    (setq *error* nil)
    (princ "\nRevision cloud program is done.")
;************************************Program begins*********************************************
  (setq OCE (getvar "cmdecho")
        OOS (getvar "osmode")
  (setvar "cmdecho" 0)
  (setq mflag nil)
  (while (not mflag)
    (prompt "\n***    Enter option C, H, L, or E    ***")
    (initget 0 "Cloud Hatch Leader Exit")
    (setq Ans (getkword "\nconvert to revision Cloud/Hatch/Leader/<Exit>: "))
    (if (= Ans nil)
        (setq Ans "Exit")
      ) ;end if
    (cond
        (  (= Ans "Cloud")
           (convcloud)
        (  (= Ans "Hatch")
           (Addhatch)
        (  (= Ans "Leader")
           (Addleader)
        (  (= Ans "Exit")
           (setvar "osmode" OOS)
           (quit)
     ) ;end cond
  );end while
);end defun
;************************************Program ends**********************************************
;*******************************Start of "convcloud" program***********************************
(defun convcloud (/ al ss)
        (initget (+ 2 4))
        (setq al (getreal "Specify Arc length <0.5>:"))
        (if (= al nil) ;If user do not input a value here
            (setq al 0.5) ;Consider "Enter" as 0.5
         ) ; end if
        (if (setq ss (ssget '((0 . "LINE,*POLYLINE,CIRCLE,ELLIPSE,SPLINE,ARC"))))
                 (command "_.revcloud" "a" al al "" (ssname ss (setq i (1- i))) "")
          (if
    (not (tblsearch "LAYER" "CONSTRUCTION"))
    (command "-layer" "N" "CONSTRUCTION" "C" "1" "CONSTRUCTION" "LT" "continuous" "CONSTRUCTION" "")
    ) ; end if
          (command ".-layer" "S" "CONSTRUCTION" "C" "red" "" "")
             (Command "Chprop" "l" "" "la" "CONSTRUCTION" "C" "BYLAYER" "Lt" "BYLAYER" "LW" "BYLAYER" "")
                );end repeat
              (princ "\nRevision cloud(s) created on CONSTRUCTION layer.")
             );end progn
           (princ "\nNo objects selected.")
);end defun
;*******************************End of "convcloud" program*************************************
;*****************************Start of "Addhatch" Program *************************************
(defun Addhatch (/ htype selset thisobj setlen entname)
        (initget 1 "D R")
        (setq htype (getkword "\nSpecify hatch type? Demo(D)/Rebuild(R):"))
        (if (= htype "D")
            (setq htype "ANSI31")
          ) ;end if
        (if (= htype "R")
            (setq htype "DOTS")
          ) ;end if
        (princ "\nSelect object(s) to hatch:")
        (setq selset (ssget))
       (if selset
           (setq thisobj 0)
           (setq setlen (sslength selset))
           (while (< thisobj setlen )
              (setq entname(ssname selset thisobj))
              (Command "-bhatch" "Advanced" "Style" "Outer" "" "")
              (command "-bhatch" "p" htype "3" "" "s" entname "" "")
       (if
 ) ; end if
              (setq thisobj(+ thisobj 1))
            ) ; end while
 (alert "\n ***WARNING***
Hatching could not skip the inner objects.
To solve this, Double click hatch and `Add: select objects'
and select inner object & click OK")
          ) ; end progn
        ) ;end if selset
);end defun
;*******************************End of "Addhatch" program*************************************
;*****************************Start of "Addleader" Program ***********************************
(defun Addleader (/ pt1)
         (while
            (setq pt1 (getpoint "\nInserting task description note, Specify Arrow End Point or hit Enter to close:"))
     (Command "_INSERT" "CP TEXT" pt1 "" "" "")
       (command "explode" "l")
          );end while
);end defun
  • 2 weeks later...
Can someone please help me on just this one?
  Quote
Thanks in advance
