shailujp Posted August 22, 2013 Posted August 22, 2013 Hi to all, So, this is my lisp. It does the following: 1) Adds revision clouds to multiple entities 2) Adds Layer (or create if required and add properties) 3) Adds hatch 4) Inserts a block for leader and text (already formated) I have very limited knowledge of the lisp. As you can see I have copied few different codes and combined it to make it work for my application. It works but I know this is not systematic at all. I dont know if my error handeling is correct. One thing that I wish to add is if the revision cloud is too big or too small, it should allow to do that without closing and undoing everything. In other sense, I need undo and reset arc length option in this. Can someone help me on this please? (defun c:RVC6 (/ *error* oce mflag ans) ;************************************Error handling********************************************* (defun *error* (msg) (setvar "cmdecho" OCE) (setq *error* nil) (princ "\nRevision cloud program is done.") (princ) ) ;************************************Program begins********************************************* (setq OCE (getvar "cmdecho") OOS (getvar "osmode") ) (setvar "cmdecho" 0) (setq mflag nil) (while (not mflag) (prompt "\n*** Enter option C, H, L, or E ***") (initget 0 "Cloud Hatch Leader Exit") (setq Ans (getkword "\nconvert to revision Cloud/Hatch/Leader/<Exit>: ")) (if (= Ans nil) (setq Ans "Exit") ) ;end if (cond ( (= Ans "Cloud") (convcloud) ) ( (= Ans "Hatch") (Addhatch) ) ( (= Ans "Leader") (Addleader) ) ( (= Ans "Exit") (setvar "cmdecho" OCE) (setvar "osmode" OOS) (quit) ) ) ;end cond );end while );end defun ;************************************Program ends********************************************** ;*******************************Start of "convcloud" program*********************************** (defun convcloud (/ al ss) (initget (+ 2 4)) (setq al (getreal "Specify Arc length <0.5>:")) (if (= al nil) ;If user do not input a value here (setq al 0.5) ;Consider "Enter" as 0.5 ) ; end if (if (setq ss (ssget '((0 . "LINE,*POLYLINE,CIRCLE,ELLIPSE,SPLINE,ARC")))) (progn (repeat (setq i (sslength ss)) (command "_.revcloud" "a" al al "" (ssname ss (setq i (1- i))) "") (if (not (tblsearch "LAYER" "CONSTRUCTION")) (command "-layer" "N" "CONSTRUCTION" "C" "1" "CONSTRUCTION" "LT" "continuous" "CONSTRUCTION" "") ) ; end if (command ".-layer" "S" "CONSTRUCTION" "C" "red" "" "") (Command "Chprop" "l" "" "la" "CONSTRUCTION" "C" "BYLAYER" "Lt" "BYLAYER" "LW" "BYLAYER" "") );end repeat (princ "\nRevision cloud(s) created on CONSTRUCTION layer.") );end progn (princ "\nNo objects selected.") ) );end defun ;*******************************End of "convcloud" program************************************* ;*****************************Start of "Addhatch" Program ************************************* (defun Addhatch (/ htype selset thisobj setlen entname) (initget 1 "D R") (setq htype (getkword "\nSpecify hatch type? Demo(D)/Rebuild(R):")) (if (= htype "D") (setq htype "ANSI31") ) ;end if (if (= htype "R") (setq htype "DOTS") ) ;end if (princ "\nSelect object(s) to hatch:") (setq selset (ssget)) (if selset (progn (setq thisobj 0) (setq setlen (sslength selset)) (while (< thisobj setlen ) (setq entname(ssname selset thisobj)) (Command "-bhatch" "Advanced" "Style" "Outer" "" "") (command "-bhatch" "p" htype "3" "" "s" entname "" "") (if (not (tblsearch "LAYER" "CONSTRUCTION")) (command "-layer" "N" "CONSTRUCTION" "C" "1" "CONSTRUCTION" "LT" "continuous" "CONSTRUCTION" "") ) ; end if (command ".-layer" "S" "CONSTRUCTION" "C" "red" "" "") (Command "Chprop" "l" "" "la" "CONSTRUCTION" "C" "BYLAYER" "Lt" "BYLAYER" "LW" "BYLAYER" "") (setq thisobj(+ thisobj 1)) ) ; end while (alert "\n ***WARNING*** Hatching could not skip the inner objects. To solve this, Double click hatch and `Add: select objects' and select inner object & click OK") ) ; end progn ) ;end if selset (princ "\nNo objects selected.") );end defun ;*******************************End of "Addhatch" program************************************* ;*****************************Start of "Addleader" Program *********************************** (defun Addleader (/ pt1) (while (setq pt1 (getpoint "\nInserting task description note, Specify Arrow End Point or hit Enter to close:")) (Command "_INSERT" "CP TEXT" pt1 "" "" "") (command "explode" "l") );end while );end defun Quote
shailujp Posted September 1, 2013 Author Posted September 1, 2013 Can someone please help me on just this one? Quote One thing that I wish to add is if the revision cloud is too big or too small, it should allow to do that without closing and undoing everything. In other sense, I need undo and reset arc length option in this. Can someone help me on this please? Thanks in advance Quote
