Does anyone know a clean way to toggle a specified flip parameter using auto lisp visual lisp?
I use the getdynprops, getdynpropvalue, putdynpropvalue [by Jeff Mishler based on code from Steve Doman, Herman Mayfarth and Tony Tanzillo] for most of my dynamic block changing needs but I can't get it they don't seem to work for the flip parameter.
Consider the following function:
[color=GREEN];; Toggle Flip State  -  Lee Mac[/color]
([color=BLUE]defun[/color] toggleflipstate ( obj )
   ([color=BLUE]if[/color]
       ([color=BLUE]and[/color]
           ([color=BLUE]=[/color] [color=MAROON]"AcDbBlockReference"[/color] ([color=BLUE]vla-get-objectname[/color] obj))
           ([color=BLUE]=[/color] [color=BLUE]:vlax-true[/color] ([color=BLUE]vla-get-isdynamicblock[/color] obj))
       ([color=BLUE]vl-some[/color]
           ([color=BLUE]function[/color]
               ([color=BLUE]lambda[/color] ( p )
                   ([color=BLUE]if[/color] ([color=BLUE]equal[/color] '(0 1) ([color=BLUE]vlax-get[/color] p 'allowedvalues)) [color=GREEN];; likely to be a flip parameter[/color]
                       ([color=BLUE]vla-put-value[/color] p ([color=BLUE]vlax-make-variant[/color] ([color=BLUE]-[/color] 1 ([color=BLUE]vlax-get[/color] p 'value)) [color=BLUE]vlax-vbinteger[/color]))
           ([color=BLUE]vlax-invoke[/color] obj 'getdynamicblockproperties)
Usage:
(toggleflipstate [color=green]<VLA-Dynamic-Block-Reference-Object>[/color])
Example program:
([color=blue]defun[/color] c:flip ( [color=blue]/[/color] obj )
   ([color=blue]if[/color] ([color=blue]setq[/color] obj ([color=blue]car[/color] ([color=blue]entsel[/color])))
       (toggleflipstate ([color=blue]vlax-ename->vla-object[/color] obj))
   ([color=blue]princ[/color])
([color=blue]vl-load-com[/color]) ([color=blue]princ[/color])
Lee Mac,
I have multiple flips states. Is there a way to pass it a the name and the parameter I want to set it to? Some are accesible by the user and some are not as they are controlled by lookup parameters.
  TheyCallMeJohn said:
Lee Mac,
Sure, in general you could use my Set Dynamic Property Value function.
For your case:
(LM:SetDynamicPropValue <VLA-Object> "UB_FLIP" 1)
or:
(LM:SetDynamicPropValue <VLA-Object> "UB_FLIP" 0)
  • 1 year later...
Hi, i have some problems with set flip parameters. I used yours "Set Dynamic Property Value" Code and:
(LM:SetDynamicPropValue <VLA-Object> "Flip_state0" 1)
(LM:SetDynamicPropValue <VLA-Object> "Flip_state1" 1)
After running the script appeared error:
Error: bad argument type: VLA-OBJECT nil
My flip parameter names:
Flip_state0
Flip_state1
My dynamic block name:
F_MOD_DIP_SW_HORIZONTAL
I need some assistance...
  • 11 months later...
Lee,
I know this is an old thread but, is there a way to make the code to where you can flip multiple blocks by window selecting them?
  BrianTFC said:
Lee,I know this is an old thread but, is there a way to make the code to where you can flip multiple blocks by window selecting them?
Certainly - please try the following:
(defun c:flip ( / i s )
   (if (setq s (ssget "_:L" '((0 . "INSERT"))))
       (repeat (setq i (sslength s))
           (LM:toggleflipstate (vlax-ename->vla-object (ssname s (setq i (1- i)))))
;; Toggle Dynamic Block Flip State  -  Lee Mac
;; Toggles the Flip parameter if present in a supplied Dynamic Block.
;; blk - [vla] VLA Dynamic Block Reference object
;; Return: [int] New Flip Parameter value
(defun LM:toggleflipstate ( blk )
   (vl-some
      '(lambda ( prp / rtn )
           (if (equal '(0 1) (vlax-get prp 'allowedvalues))
                   (vla-put-value prp (vlax-make-variant (setq rtn (- 1 (vlax-get prp 'value))) vlax-vbinteger))
                   rtn
       (vlax-invoke blk 'getdynamicblockproperties)
(vl-load-com) (princ)
Toggle Flip State function from here.
Lee,
Does your Flip.lsp program flip only the first Flip parameter encountered? What if there are more than one flip parameters defined in the dynamic block?
Lee,
Thank you so much!!!! :beer:
Brian
  Louderjohn said:
Lee,
Currently yes - change vl-some to mapcar to toggle all Flip parameters held by the block. :thumbsup:
  BrianTFC said:
Lee,
Brian
You're welcome!
I like it and probably is a good reason to give blocks a flip parameter
With more dynamic feature it fails unexpected.
(tested only a little bit...)
