moj_mah Posted August 10, 2013 Posted August 10, 2013 Hi, I can't use F8 key for Ortho mode in Auto Cad 2012. I checked CUI and it seems to be ok but when I press the F8 key It doesn't work. as matter of fact, after pressing F8 key, line type manager window is opened!!!! Ican't work and it makes me crazy. HELP HELP thank you Quote
ReMark Posted August 10, 2013 Posted August 10, 2013 Did you customize your CUIx at some point? Quote
nestly Posted August 10, 2013 Posted August 10, 2013 Do the other Function keys work in AutoCAD? Fn lock turned on? Quote
moj_mah Posted August 10, 2013 Author Posted August 10, 2013 Hi, I'm amateur. I don't know How customize that. can you help me, please? thank you Quote
moj_mah Posted August 10, 2013 Author Posted August 10, 2013 Hi, I can't use the PrtSc key too.And there is no key on keyboard for turning on/off Keys. what can I do? Quote
nestly Posted August 10, 2013 Posted August 10, 2013 Does Ortho toggle ON/OFF when you click the Ortho button on the status bar? Does Ortho toggle ON/OFF when you press the F8 key? Does F7 turn the GRID ON/OFF Quote
nestly Posted August 10, 2013 Posted August 10, 2013 moj_mah said: Hi,I can't use the PrtSc key too.And there is no key on keyboard for turning on/off Keys. what can I do? It sounds like Fn Lock is turned on (similar to CapLock & NumLock) Is there an indicator for that on your keyboard? Quote
moj_mah Posted August 11, 2013 Author Posted August 11, 2013 I checked, didn't work even when Ortho was on! Quote
moj_mah Posted August 11, 2013 Author Posted August 11, 2013 yes. I changed it but it doesn't work Quote
ReMark Posted August 11, 2013 Posted August 11, 2013 Reset your Profile and see if that makes a difference. Quote
nestly Posted August 12, 2013 Posted August 12, 2013 moj_mah said: Hi,I can't use the PrtSc key too.And there is no key on keyboard for turning on/off Keys. what can I do? Can you turn Ortho on/off using the status bar toggle instead of F8? Does F7 work to turn the grid on/off? Did F8 work previously or is this a new computer? Quote
SLW210 Posted August 12, 2013 Posted August 12, 2013 Do the Function keys work properly in other programs? Quote
