sandiegophil Posted August 3, 2013 Posted August 3, 2013 Hello, I am short on time and looking for a fast fix. I have the following situation: 100+ pipe network All alignments are in place and named correctly and styles applied 80% of the pipes are the same size and type Does anyone know a way to make a pipe for each alignment named the same as the alignment and all in a single pipe network? Ideally selecting all the alignments at one time and have the pipe style applied. I know the answer is probably 'tough beans' but I thought I'd give it a try. Thanks, Phil Quote
