Need help please...
May i ask why is it that in cad when i render.. it takes centuries....
- settings for my renderings are:
Fg n gi is on st to 500 and 1.
-sky n background illumination
Rendering references to high w/ 1024×768...
My other problem is that using a higher output makes my rendering more sharp to zoom but i expected it positively but the outcome is the same as the lower image output yet everything is so long to render...
Im only using pure cad.. no after programs.
Any recomendation/suggestion will do... thank you.
If the rendering time for the low resolution output is the same as the time for the high resolution output, there is something wrong with your settings. If you can post some screenshots of your high res and low res settings, maybe someone can figure out what's wrong.
Im using the hp touch smart 610 3-in-1 pc???
Please find attached images for a sample work...
the two rendering has the same setting buy different view and output size..yet its only an hour more difference.
Thank you.
OK we now know the brand of PC what about the specs? If you are rendering in AutoCAD then it relies only on the cpu for rendering. Perhaps it's time to look at another rendering solution? It shows you use Acad 2008, that has an earlier version of Mental Ray that handles it's rendering. So you should be able to tweak it a bit to speed it up.
Do you have the Core i3, i5 or i7 version of the Touch Smart 610?
My apologies....
windows 7ultimate
Service pack 1
i7 870 @ 2.93 ghz
8g ram
64 bit os
ati radeon hd 5570 display adapters.
?..and for the program... this is done in cad 14... just shifted from cad 08 which is best ive used ever since.
?..do i have a problem or i have to find another solution for rendering...
Im looking to go forward to max yet it will be back to zero... started it already but needs a huge help.... questions and patience....
Well you'd think a HT quad core cpu would be a bit faster. Sure that is a 1st gen i7 but it is still an i7. Perhaps there are some settings to enable the usage of all your cores. I mean you technically have 8 threads to use. Did you get AutoDesk Showcase with your AutoCAD 2014?
Is a standard i5 @3570k 3rd Gen better than the i7 first gen?
nice drawings btw :D
Thnak you....
...f700es... since on the 2nd set of attched images, i have a huge number of light... does it affect that much???
When i turned off the light and render it at different time, it didnt render that long...
Pointlight
- min is 100 intensity
- soft sampled to cylinder shape with 100 radius and 50 length.
