KTS Posted July 31, 2013 Posted July 31, 2013 Hi there, Am having trouble drawing a ring beam round a building structure at an elevation of +2400 mm above floor level. Any help/ideas will be appreciated Thanks Quote
Dadgad Posted July 31, 2013 Posted July 31, 2013 Draw the profile of the shape of your ring beam in 2D. Create a polyline describing the PATH around the perimeter of the structure. Use the SWEEP command with the PATH option to create a 3D model of it. Once created you can set the correct elevation. Quote
