Alex11 Posted July 17, 2013 Posted July 17, 2013 Hi everyone, I was wondering if I can run a lisp in AutoCAD from building (running) a C++ code in Visual Studio. What I mean is can I have AutoCAD open and run a C++ code in parallel and have the lisp loaded automatically in AutoCAD? The lisp I want to use is 'ascpoint', which gets a text file with coordinates as input and inserts points at those coordinates. Any help will be really appreciated. Thanks, Alex Quote
BlackBox Posted July 17, 2013 Posted July 17, 2013 Welcome to CADTutor, Alex; and congrats on your first post! Alex11 said: I was wondering if I can run a lisp in AutoCAD from building (running) a C++ code in Visual Studio. What I mean is can I have AutoCAD open and run a C++ code in parallel and have the lisp loaded automatically in AutoCAD? Firstly, is there a reason you're not instead simply debugging a new AutoCAD process? Given that ObjectARX (C++), like .NET (C#, F#, VB, etc.) compiles to an assembly which in turn needs to be [ARX/NET]-loaded into your active session (process) of AutoCAD... Doing what you're after is impossible for a .NET assembly (as there is no such NETUNLOAD CommandMethod/LispFunction Method), however, I suspect that your ARX *might* be able to as it can be subsequently ARXUNLOAD-ed. Methinks that your VS Project may need to obtain the active AutoCAD Process, and use the COM API to invoke the LISP (not sure what APIs ARX exposes for this sort of thing?). I typically code .NET plug-ins which are loaded at session start, or on demand, so I'm afraid that I cannot be of more help to you here, as ObjectARX is not (yet) a language which I am adept. The only other advice I can offer is that ARX can call LISP directly via acedInvoke() Method. Quote
Bill Tillman Posted July 17, 2013 Posted July 17, 2013 (edited) Short answer is yes. You can build a C# project which will either open AutoCAD or use an existing instance of it already open, then send a command to it which will load and run a LISP program of your choice. I do it all the time. I use the COM method, preferring to stay outside of the AutoCAD environment as much as possible. The LISP code I use also reads text files for input to create drawings. Oh, I should mention that I use VB.NET. If you search the Internet, you'll find numerous examples of how to do this. It will look something like this. You will need to add a reference to AutoCAD for this. Imports AutoCAD Module LaunchAutoCAD '************************************************************************************************************** ' LAUNCH AUTOCAD & LISP '************************************************************************************************************** Sub Launch_AutoCAD(ByVal DwgName As String) Dim vAcadApp As AcadApplication Dim vAcadDoc As AcadDocument Dim DwgPath As String = "\\My_Path_To\Engineering\Automated Drawings\" Dim LispPath As String = "//My_Path_To/LISPFiles/" Try If Process.GetProcessesByName("acad").Length > 0 Then vAcadApp = GetObject(, "AutoCAD.Application.19") Else vAcadApp = New AcadApplication End If vAcadApp.Visible = True vAcadApp.WindowState = AcWindowState.acMax vAcadDoc = vAcadApp.Documents.Open(DwgPath & DwgName, True) vAcadDoc.SendCommand("(load """ & LispPath & My_Lisp & ".lsp"" ""The load failed"") " & Cmd_To_Start_LISP_Program & Chr(13)) Catch ex As Exception Finally vAcadApp = Nothing vAcadDoc = Nothing End Try End Sub This code was shared with me about a year or so ago and it's configured for AutoCAD 13. It also leaves the instance of AutoCAD open as my project receives request from over the Internet 24/7. There may well be better methods but this works for my needs. Edited July 17, 2013 by Bill Tillman 1 Quote
Alex11 Posted July 18, 2013 Author Posted July 18, 2013 Thanks for the response! I'm not sure what you mean by "simply debugging a new AutoCAD process". Unfortunately I'm kind of new to this area (using Lisp and running codes to make something happen in AutoCAD). I don't insist on using Lisp to make what I want happen. I even rather not to use it! What I'm trying to achieve is writing a piece of C++ code, which after running will make AutoCAD get a text file containing coordinates as input and insert points at those coordinates (without the need to do anything in AutoCAD). Could you help me in this direction please? Thanks a lot, Alex Quote
Alex11 Posted July 18, 2013 Author Posted July 18, 2013 Hi Bill, Seems like what I am looking for! But could you please elaborate a bit on how I can get this running? I did a search on internet but no success. Thanks, Alex Quote
BlackBox Posted July 18, 2013 Posted July 18, 2013 Alex11 said: Thanks for the response!I'm not sure what you mean by "simply debugging a new AutoCAD process". Unfortunately I'm kind of new to this area (using Lisp and running codes to make something happen in AutoCAD). I don't insist on using Lisp to make what I want happen. I even rather not to use it! What I'm trying to achieve is writing a piece of C++ code, which after running will make AutoCAD get a text file containing coordinates as input and insert points at those coordinates (without the need to do anything in AutoCAD). Could you help me in this direction please? I'm swamped at the moment, but for obtaining an instance of AutoCAD, given this thread a read. You should be able to do what you're after without calling LISP from the ObjectARX (C++) API natively... I'm a .NET API guy (C#, VB.NET), unfortunately. FWIW - Especially if you're new to development with AutoCAD, if you're not already adept at C++, you could easily hop into C# instead, as it too can do everything you're after here. Cheers Quote
Alex11 Posted July 18, 2013 Author Posted July 18, 2013 BlackBox said: I'm swamped at the moment, but for obtaining an instance of AutoCAD, given this thread a read. I just looked at this thread and the first post there by Bill is exactly what I'm looking for. I just have issues running it. I need to know what's the rest of the code and what references I need to add and etc. It would be great if I could get that code running. And it's fine for me to use VB. Thanks a lot, Alex Quote
Bill Tillman Posted July 18, 2013 Posted July 18, 2013 First, I see you're running AutoCAD 2012. I think the number 19 changes to 18 for that version. As for the rest of the code, that could be answered in many ways. There's always more than one way to do something with AutoCAD and .NET projects. The above code though should get you started by either opening up AutoCAD or using an existing instance of it. Once your project executes the "SendCommand" portion it will open any LISP file you want and then execute it. That LISP file could be one which reads a text file of points and places them in the model space for you. I think you could also do this inside the AutoCAD environment. My projects are totally automated, no user input allowed. Your setup sounds a little different so you really could use either just C#.NET, VB.NET or plain old LISP itself. LISP can open and read text files quite easily. Outside of that we'd need to know more about your file format, etc... to offer advice. Excuse me, but I now see you're wanting to run ascpoint.lsp, which is an already existing LISP program. The code above can be pointed to just such a file, but again, I'm not clear on why you need to use another development environment to run it. If you can explain a little more on why you need a 2nd development platform to run this LISP that might be helpful. Quote
Alex11 Posted July 19, 2013 Author Posted July 19, 2013 Bill, What I am trying to achieve is making a VB code that when I run it, will read a text file containing coordinates and insert a point at that coordinates in AutoCAD. I also want it automated and I don't want to do anything (such as typing a command) in AutoCAD. I would appreciate it if you could help me in that direction. Also, could you let me know what references to add for the code above? Thanks a lot, Alex Quote
Bill Tillman Posted July 22, 2013 Posted July 22, 2013 Sorry for the delayed reply. You will need to add the reference for your version of AutoCAD, which in your case would be "AutoCAD 2012 Type Library". You will find this under the COM tab when you add the reference. Now the trouble with this method is that if you want the VB.NET program to run in the AutoCAD environment Quote will read a text file containing coordinates and insert a point at that coordinates in AutoCAD you will not use the COM reference. You can do this, I'm not up to speed on it that well as I use the COM method. By that I mean I use VB.NET to load/open AutoCAD, start a drawing template, then load and execute a LISP file which does all the work. In your case, the LISP file would read your text file and insert the points. There are several LISP files already out there which do this. Lee-Mac has one on his site, and Jeffery Sanders has XYZImport.lsp which does a good job of this. Customizing it to your needs will required some more doing though. We'll all try to help as much as we can. Post back with what you've got done so far. Quote
patelankitm Posted August 5, 2013 Posted August 5, 2013 I am trying to run this code and getting "Error Binding to the method." I am running AutoCAD Architecture 2014. <CommandMethod("SMB", CommandFlags.Session)> _ Public Sub SMB(ByVal DwgName As String) ' LAUNCH AUTOCAD & LISP 'Sub Launch_AutoCAD(ByVal DwgName As String) Dim vAcadApp As AcadApplication Dim vAcadDoc As AcadDocument Dim DwgPath As String = "\\\..... Dim LispPath As String = "..... Dim My_Lisp As String = "SMBTEST" Dim Cmd_To_Start_LISP_Program As String = "SMBRUN" Try If Process.GetProcessesByName("acad").Length > 0 Then vAcadApp = GetObject(, "AutoCAD.Application") Else 'vAcadApp = CreateObject("AutoCAD.Application.20") vAcadApp = New AcadApplication End If vAcadApp.Visible = True vAcadApp.WindowState = AcWindowState.acMax vAcadDoc = vAcadApp.Documents.Open(DwgPath & DwgName, True) vAcadDoc.SendCommand("(load """ & LispPath & My_Lisp & ".lsp"" ""The load failed"") " & Cmd_To_Start_LISP_Program & Chr(13)) Catch ex As System.Exception Finally vAcadApp = Nothing vAcadDoc = Nothing End Try End Sub Quote
BlackBox Posted August 5, 2013 Posted August 5, 2013 patelankitm said: I am trying to run this code and getting "Error Binding to the method." I am running AutoCAD Architecture 2014. You've coded a CommandMethod Method (a plug-in) which is trying to access the Application Object from the Process (typically done from a stand-alone application via COM), when you could instead just get the Application Object from Autodesk.AutoCAD.ApplicationServices.Application HTH Quote
Bill Tillman Posted August 5, 2013 Posted August 5, 2013 Yes, what BlackBox said....but it's often hard for us novice and beginners to understand that jargon and buzzwords. Basically what he's saying is the code I provided for you was intended to be run as a stand-alone program, or what is known as the COM method. The first lines in your code are approaching it from the other end of the spectrum, that is you're trying to code something meant to run inside of the AutoCAD environment itself. Perhaps other more experienced people here can elaborate on this for us. I typically program using the COM method, but others prefer the Application method. If you're trying to run this while you have AutoCAD already running an opened drawing, then you need to look at something different than what I provided. The method I posted is basically for a machine sitting there idle or only has AutoCAD opened with no drawing file loaded. And a compiled exe program is run without AutoCAD ever knowing about it until it gets called upon from that compiled exe. The automation coding I do is not suited well for the Application method, thus I run everything from outside of AutoCAD. I hope I didn't muddy the water too much there. I cannot by any means claim to be an expert on this subject. Quote
patelankitm Posted August 5, 2013 Posted August 5, 2013 I figure out this with lots of trials, though. I am have created a stand alone application via COM now. I am able to launch AutoCAD, but when I send the command I get "the load failed." Can you point to me what wrong with my code? Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load Const progID As String = "AutoCAD.Application.19.1" Dim acApp As AcadApplication = Nothing Dim LispPath As String = "..." Dim My_Lisp As String = "SMBTEST" Dim Cmd_To_Start_LISP_Program As String = "SMBRUN" Try acApp = DirectCast(Marshal.GetActiveObject(progID), AcadApplication) Catch Try Dim acType As Type = Type.GetTypeFromProgID(progID) acApp = DirectCast(Activator.CreateInstance(acType, True), AcadApplication) Catch MessageBox.Show("Cannot create object of type """ + progID + """") End Try End Try If acApp IsNot Nothing Then acApp.Visible = True acApp.ActiveDocument.SendCommand("(load """ & LispPath & My_Lisp & ".lsp"" ""The load failed"") " & Cmd_To_Start_LISP_Program & Chr(13)) End If End Sub Quote
BlackBox Posted August 6, 2013 Posted August 6, 2013 I'm not sure what jargon, or buzzwords I could have used... What I said was direct. If another member doesn't know the difference between .NET and COM interfaces; that's fine, but having never coded a COM app myself (unless you count Visual LISP, which I do not), I rather consider myself a beginner with regard to .NET API. The little I know, I may know well, but that is hardly indicative of being an expert (which I am not)... I was actually trying to be helpful, believe it or not. Cheers Quote
