kpyoung333 Posted July 16, 2013 Posted July 16, 2013 I couldn't find what this was made with, but is the lathe/mill action from :30 to :50 possible in inventor? I can get the animation to rotate and have the parts spin, but cannot figure out how to make the milling command take the surface down. Might this have been made with Maya? or some CAM software? I was hoping to use inventor to show how to make drill bits and contacts with the parts milled out from a single stock. Any ideas? If not possible, what is a program that I can use that my inventor/autocad skills will be able to translate easily? Quote
Bishop Posted July 16, 2013 Posted July 16, 2013 Not certain what software was used for that, but it certainly wasn't Inventor. Doesn't look like CAM software either. It was probably done with Max or Lightwave or similar. Maybe Maya, but it seems that Maya is more used for character visualization, not so much hard surfaces and mechanical. Maybe Cinema4D? Quote
Lazer Posted July 24, 2013 Posted July 24, 2013 You can do that in a number of programs. It would also take an experienced person to do it, not really something you can throw into Inventor Studio and show the boss over night, sorry. Quote
Bishop Posted July 24, 2013 Posted July 24, 2013 You can do that in a number of programs. It would also take an experienced person to do it, not really something you can throw into Inventor Studio and show the boss over night, sorry. Just wanted to highlight the bit about experience: That's almost certainly a solid 40-60 man-hours of work just modeling, rigging and animating, and that's assuming you're an expert user of whatever you're going to use. I'd probably model in modo, animate and render in Lightwave, except for the morph maps for the workpieces. That would be modeled and animated in Lightwave. Quote
kpyoung333 Posted September 29, 2014 Author Posted September 29, 2014 http://youtu.be/o4JYzDHUO7g I animated the extrusion to simulate a cutting action. This can be done to show a milling action too, just haven't modeled it. Not as in depth as their video obviously but shows pretty much all possible animations in Inventor (notice the sweep stops cutting one part and continues cutting another, the pin springs move and compress, the nut fades out, rotation while zooming). Didn't take long to make or animate and turned out pretty good, thought I would share. Quote
Lazer Posted September 30, 2014 Posted September 30, 2014 Thanks for sharing always nice to see new things Quote
lrm Posted October 21, 2014 Posted October 21, 2014 The lathe/mill action can be easily done in 3DS Max by key framing the vertices of the spline that define the revolved shape. Quote
