Hi,
I need help on 1. clipping 3D Drawing views and 2. chaging the hatch pattern/scale in the sectional Drawing views that the generated automatically when hatch option is on. A last question is whether Sectional Drawing view is better than a section generated with section plane. Thanks.
I have moved your question to the Autocad 3D modeling section. You posted in the Studio Max modeling section. ;)
you know the VIEWBASE command ? it has all the option you mentioned in autocad 2014 including hatch patterns in a sectional view where you cut a solid
Ok.
Thanks you very much for the info. I will try it and revert back to you as soon as I complete the modelling process.
Note that the 2D views created by the ViewBase command are placed in a paper space layout.
