I have many line drawings done on auto cad but need to transfer them and edit (colour fill) these in illustrator. have exported, saved in eps pdf you name it i,ve done it......has anyone or is anyone doing this often? help! why didn't I just do all the drawings in illustrator first ?.......autocad trained for years........illustrator very new to me:oops::cry::?
Illustrator should open your drawing file.
What version of Illustrator?
thankyou for the quick reply.......i,ve got a trial version so its version 6........ 3 days left!
I have Illustrator CS2 and you have to save the drawing to vers R14 to get them in Illustrator CS2.
You might look at Inkscape, it will open a R13 dxf from Autocad and is FREE open source.
Yeah, I've done this before from time to time.
  • 2 months later...
I've done this many times before. I knew Illustrator way before I learned AutoCAD.
I assume you mean Illustrator CS6? Illustrator 6 was released in 1996.
I have Illustrator CS5 and I can open 2007 format dwg's, although I do get a warning about object attributes not being preserved. I can still open the dwg though.
2004 format opens just fine, with no warning messages.
