unable to start autocad LT
Hi,
I have this problem with autocad LT 2007 running on Windows 7 Pro 64-bit.
The problem might be to do with permission or some sorts.
I (as administrator) can launch the autocad under my account. However, some users with power-user permissions are having trouble getting it started. Nothing happens after double-clicking on the icon on the desktop.
Then, what puzzles me even more is that another user (called autocad-user) logs in and is able to launch the app with no drama. Now, I also realized that when the autocad LT 2007 got installed in the first place, it's done by this user (autocad-user). This explains why this particular user can run the app besides administrators.
But I just wonder why not all other authorized users can run it. It's the same machine but just shared by different users.
Any help would be greatly appreciated.
Thank you
What happens if you right click on the icon and check RUN AS ADMINISTRATOR?
Thanks for your reply.
No, I tried it already and it still didn't work.
I had to switch users either to myself or autocaduser, then tried it again and it worked. Really bizarre.
Thank you very much
Have you tried opening through the Programs menu?
Thank you for your reply.
Yes, I tried that too and nothing showed up afterwards.
very strange.
Thank you
very strange.
Thank you
On which user account are you tring to open it?
I found the following error message under Event Properties:
Faulting application name: acadlt.exe, version: 23.0.54.0, time stamp: 0x440adc1d
Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec49b60
Exception code: 0xc0000005
Fault offset: 0x00034cb3
Faulting process id: 0x73c
Faulting application start time: 0x01ce81f20336e922
Faulting application path: C:\Program Files\AutoCAD LT 2007\acadlt.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 41be9ed4-ede5-11e2-8cb5-001bfc3b3
Don't understand what the error means.
Thank you very much
Perhaps send that error to Autodesk?
That would be pointless as AutoDesk does not support running AutoCAD 2007 under Win7.
I wasn't aware of that. Or, at least forgot when thinking about the best way of going about this. :oops:
I guess a fresh install has been tried, or something you want to avoid if possible?
