Hi,
I am able to import Microsoft works spread sheat as an OLE but not the Microsoft works word.....ACAD LT 2013....Any help?:)
Plain paste work on my end.
I'd junk "Works" and download OpenOffice. It's FREE.
To learn more about OpenOffice see this...http://www.openoffice.org/
I sorry, didn't notice "MS Works". I use "MS Office"
Second that, Remark.
Tried the open office but couldn't link document as ole. Message was not in registry. Could save as PDF and then drop it in...rather inconvenient but it works, Any further suggestions would be appreciated.
Jim
Can you attach a copy of the Work's file you are currently work with to your next post?
What steps are you taking to insert OLE?
As ReMark asked, can you post the Works file?
Hi,
I have tried dragging the file, INSERTOBJ, insert OLE using the menu and choosing the file and checking link, and creating a new OLE by choosing open office app that is in the drop down menu. All without success.
When I drag it in it seem to go fine but I get the circle for a minute then nothing.
When I INSERTOBJ I only get about 1/2 of the first page.
If I try to create a new OLE message is (FAILED TO CREATE OBJECT. MAKE SURE THE OBJECT IS ENTERED IN THE SYSTEM REGISTRY)
Downloaded the open office from openoffice.org
Any suggestions would be appreciated.
Jim:)
Was unable to upload file ....invalid file type.
Jim:)
Change the file extension to TXT and see if you can upload it then. What is the normal file extension? Nevermind...it must be WPS right?
here is the file original ext .odt.....loved it back when you could access your hard drive directly...long time ago had to remember I had to copy it to a flash drive to change the ext. LOL.:)
test.txt
works word ole not supported by ACAD
I can INSERTOBJ and even edit the entire document in the .dwg with open office just doesn't display the entire document only about 1/3 of the document.
