fahim108 Posted July 6, 2013 Posted July 6, 2013 Is there any Command / Lisp / Parametric way of obtaining a "prospective" ellipse from a set of 5 points? I found a similar question here, but no solution. Quote
JD Mather Posted July 6, 2013 Posted July 6, 2013 What are the (x,y) coordinates of the 5 points? Quote
fahim108 Posted July 6, 2013 Author Posted July 6, 2013 P1 (0.6504, 0.1714), P2 (0.6722, 0.1834), P3 (0.7011, 0.2022), P4 (0.7408, 0.2338 ), P5 (0.7977, 0.2927) I'm fiddling with the Geometric Constraints option but haven't gone far enough! Quote
JD Mather Posted July 6, 2013 Posted July 6, 2013 The dimensions in (parenthesis) are for reference only. I was able to easily find the geometric solution in Autodesk Inventor. (I thought I would have to have beyond 4 decimal places, but only if the major and minor axis had to be a known value.) I will have to experiment in AutoCAD to see if I can get AutoCAD to solve the problem. Oops, I realized I made a mistake in the y-coordinate of P5. This is the beauty of parametric geometry constraints - I only had to edit the dimension to correct the solution. Quote
fahim108 Posted July 12, 2013 Author Posted July 12, 2013 (edited) Here is my solution: 5-Point Ellipse I've loaded the LISP but am unable to call it? I tried entering test but it doesn't work! Am I doing something wrong? I will have to experiment in AutoCAD to see if I can get AutoCAD to solve the problem. Any luck? Edited July 12, 2013 by fahim108 Added quotes! Quote
Lee Mac Posted July 13, 2013 Posted July 13, 2013 I've loaded the LISP but am unable to call it? I tried entering test but it doesn't work! Am I doing something wrong? Have you downloaded & loaded the 5PointEllipse.lsp program (from the download link found at the top of the page), before saving & loading the short example program at the bottom of the page? Quote
