automaticad Posted July 5, 2013 Posted July 5, 2013 How to draw the curve exactly similar such as the attached image in AutoCAD? Quote
JD Mather Posted July 6, 2013 Posted July 6, 2013 Those are unitless "weights" added to the curve to control curvature in SolidWorks. Quote
automaticad Posted July 7, 2013 Author Posted July 7, 2013 How to draw the curve using the CV method? Quote
ReMark Posted July 7, 2013 Posted July 7, 2013 Isn't the Control Vertices available on the Grip menu? Are you really using AutoCAD 2000 or did you fail to update your Profile? Options may vary depending on the version of AutoCAD one is using. Here is one explanation regarding the use of the Control Vertices Method: http://www.g-wlearning.com/CAD/9781605253282/student/ch04/PDF/SupMat03.pdf Quote
welldriller Posted July 9, 2013 Posted July 9, 2013 First i printed the image in post #1 Then using autocadLT 2000 i did the following and got a perfect fit i only used 3 lines and a arc (this was done in metric) line 1 = @171.50 line 2 = @442.50 line 3 = @221.25 with osnap turned on pick arc pick the end points of each line print out your new drawing and cut it out mine was a perfect fit over the image i printed from post #1 yep bet a dollar to a donut ReMark checks me on this one. Quote
