A1DWG Posted November 20, 2008 Share Posted November 20, 2008 Hi All, just joined today, so my first post... Anyway just looking around and reading some posts, anyone able to help with this? I want to use a formula in the dim command to divide the length "" by a given value, ie 300, and then add 1. ie 3000/300+1 to give a figure of 11. Please help. On the idea of sharing, I have a bit of experience in creating linetypes and hatchpatterns, if anyone has any specific ones they would like, let me know. Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 20, 2008 Share Posted November 20, 2008 Firstly, welcome. Now your problem... I'm not aware of a way of doing this directly. I thought it may be possible using a field but what I tried didn't work. I was about to suggest that there may be a programmimg solution but I now see you are using LT so that isn't an option. If you want this so you can say "I need 11 bricks to build this wall" you can get most of the way there changing your measurement factor in a dimstyle. If you do this I would suggest you also add the sufix so you know it isn't measuring real units. Quote Link to comment Share on other sites More sharing options...
totzky Posted November 21, 2008 Share Posted November 21, 2008 Hi! A1DWG, Try experimenting with 1) DIMLFAC 2) 'CAL or the built in Calculator and 3) DOV. These are the closest thing I can think of regarding your question. Quote Link to comment Share on other sites More sharing options...
totzky Posted November 22, 2008 Share Posted November 22, 2008 Please find the attached file as an explanation for my previous post. Hope you'll get an idea on how to arrive at your "11" . dimlfac.dwg Quote Link to comment Share on other sites More sharing options...
