I made a very simple lisp to draw a line according to a requested slope ratio like 1:4, 1:10 ect
it works fine for "normal" angles, but when it comes to ratio like 1:60 or 1:0.001 the result is inconsistent...
I mean sometimes it will be displayed fine, or on the x axis (ie with no inclination at all) or will draw only a point with no length or will snap to another line (sitting very close)
And all of that even if the values for the end point are correctly computed...
Something else, if I draw a very long line like (1700 m) then it's always displayed correctly...
If someone has an idea/ explanation
I'll be very thankfull
here is the code
(defun C:slp( / refpt dirpt x_ratio seglen xref yref dirangle reqangle xend yend)
   (setq refpt (getpoint "\nPick a reference point"))
     (setq dirpt (getpoint "\nPick a direction point"))
     (setq x_ratio (getreal "\nSlope ratio 1:"))
     (setq seglen (distance refpt dirpt))
     (setq xref (car refpt))
     (setq yref (car (cdr refpt)))
     ;zref=0
     (setq dirangle (angle refpt dirpt))
     (setq reqangle (atan 1 x_ratio))
     (princ (strcat "\ndirection angle: " (rtos dirangle) " requested angle: " (rtos reqangle)))
     (cond (
              (and (> dirangle 0) (< dirangle (/ pi 2)))
                  (setq xend (+ xref (* seglen (cos reqangle))))
                  (setq yend (+ yref (* seglen (sin reqangle))))
                  (setq endpt (list xend yend 0.00))
                  (command "pline" refpt endpt "")
           (and (> dirangle (/ pi 2)) (< dirangle pi))
                  (setq xend (- xref (* seglen (cos reqangle))))
           (and (> dirangle pi) (< dirangle (/ (* pi 3) 2)))
                  (setq yend (- yref (* seglen (sin reqangle))))
       (and (> dirangle (/ (* pi 3) 2)) (< (* pi 2)))
Thank you all
That seems to be a conflict with your current auto OSNAP settings; please try to adjust the commands calls like below:
(command "pline" [color=red]"_non"[/color] refpt [color=red]"_non"[/color] endpt "")
It's perfect now ! thanks a LOT!
