Hello
Now that the problem with OS, XP, W7, 16bit, ... is solved with this little lisproutine, which I'm very happy for it, I discover another small limitation.
I noticed that it only measures arc's and no lines. Is it possible to fix this problem?
It would be great if it also can measures lines (at the same time time) :) Does anybody can help me with?
Thx in advance
Gr
ARCRLVOOR_DimVoorSnijden.lspUnavailable
  Tharwat said:
Would this thread be any assistance ?
A little bit :( Thx Tharwat.
The dimlisp of the lines works great but that's only for lines. The dimlisp of the circles doesn't work on my pc. Maybe it is because I've a 64-bit OS?? I don't know.
My wish is that I've one lisproutine that can do the both things. Measure lines and arcs. For the arcs you can use the lisproutine above ;)
I don't have the skills to fix this :oops:. I hope somebody has :)
gr
