stenna Posted June 26, 2013 Share Posted June 26, 2013 Morning again, Is there a lisp or piece of code that would change the contents of a block to Layer 0, so I can set it down in my Layering Standard rather than the standard the block was created in (not by me). Look forward to hearing from you Stenna Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 26, 2013 Share Posted June 26, 2013 Take a look at this thread and pay particular attention to Lee Mac's response (and code) in post #6. http://www.cadtutor.net/forum/showthread.php?50422-Change-layer-of-Block-Elements Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 26, 2013 Share Posted June 26, 2013 Almost the same like the one that I have posted in your second thread with a little modifications to suit the needs . (vl-load-com) (defun c:2lay0 (/ b o) ;;--- Tharwat 26.June.2013 ---;; (or doc (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))) (vlax-for b (vla-get-blocks doc) (if (and (eq :vlax-false (vla-get-isLayout b)) (eq :vlax-false (vla-get-isXref b)) ) (vlax-for o b (vla-put-layer o "0") ) ) ) (vla-regen doc acAllViewports) (princ) ) Quote Link to comment Share on other sites More sharing options...
