Change Block layer to Level 0
stenna
Morning again,
Is there a lisp or piece of code that would change the contents of a block to Layer 0, so I can set it down in my Layering Standard rather than the standard the block was created in (not by me).
Look forward to hearing from you
Stenna
Almost the same like the one that I have posted in your second thread with a little modifications to suit the needs . :)
(vl-load-com)
(defun c:2lay0 (/ b o)
 ;;--- Tharwat 26.June.2013 ---;;
 (or doc (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))))
 (vlax-for b (vla-get-blocks doc)
   (if
     (and
       (eq :vlax-false (vla-get-isLayout b))
       (eq :vlax-false (vla-get-isXref b))
      (vlax-for o b
          (vla-put-layer o "0")
 (vla-regen doc acAllViewports)
