Morning All,
Is the a lisp or some code to delete a hatch from every block in a drawing. The super market chain I'm working with use the same blocks over and over on different projects but there is a hatch on most of the blocks which interferes with my phasing drawings.
I've tried Freezing/Turning Off the layer but as they have not set the blocks up with layer intelligence that doesn't work.
I'm not worried about loosing the information contained within there blocks as I'm working for the builder producing CAD files that are only issued in PDF format. I don't want to explode the blocks!
Look forward to your comments
Please do not double post. Try to show some patience. We're all just volunteers here. Thank you.
Try this ..
(vl-load-com)
(defun c:Test (/ b o)
 ;;--- Tharwat 26.June.2013 ---;;
 (or doc
     (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
 (vlax-for b
             (vla-get-blocks
               doc
   (if
     (and
       (eq :vlax-false (vla-get-isLayout b))
       (eq :vlax-false (vla-get-isXref b))
      (vlax-for o b
        (if (eq "AcDbHatch" (vla-get-objectname o))
          (vl-catch-all-apply 'vla-delete (list o))
 (vla-regen doc acAllViewports)
if they are the same blocks used many times in different drawings you only need to modify one instance of each block, behaps using BEDIT or Tharwat's code. Then having modified all the necessary blocks in a single "master" drawing you can use the Design Centre to redefine the blocks in any current drawing.
  • 2 months later...
Tharwat,
I've finally had 5 mins to look at your code; it works just fine many thanks apart from one thing could you amend the code so it only works on selected items rather than across the whole drawing. We have a number of blocks that we now use that contain gradient fill/hatching and I don't want to delete the the hatch from them.
Look forward to hearing from you
Thanks again Stenna
Tharwat,
Try this ...
(vl-load-com)
(defun c:Test (/ ss i sn name bd l)
 ;; Tharwat 18. Sep. 2013     ;;
 (or acdoc
     (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
 (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
     (setq sn (ssname ss (setq i (1- i))))
     (if (not
           (member (setq name (cdr (assoc 2 (entget sn)))) l)
         (setq l (cons name l))
         (vlax-for x (setq bd
                            (vla-item (vla-get-blocks acdoc)
                                      name
           (if
             (and (eq :vlax-false (vla-get-isxref bd))
                  (eq (vla-get-objectname x) "AcDbHatch")
              (vl-catch-all-apply 'vla-delete (list x))
 (if ss
   (vla-regen acdoc acAllViewports)
I have just used it for the first time in the last five minutes and it works a blinder.....super coding
Many Thanks :D
Many Thanks :D
Happy to hear that at last :D
  • Funny 1
You've saved me about 2 hours of editing blocks this evening. Many thanks
Best of luck and happy CADing :)
  • 1 year later...
Good morning to you all , loading the lisp indicated by the following error :
; error: syntax error
you know help me?
Mirco
