Autodesk Design Review Scale Issues
Hi All,
I am having an issue where drawings Published from AutoCAD as DWF files measure differently between Layout and Model in Design Review. To test I drew a cube 1000x1000x1000mm and in the layout it measures correctly but in the Model it measures 1000in (or 25400mm when the 3D Units are changed to Millimeters)
Even when I set the 3D Units to Millimeters by default and re-open the drawing, the measurement is still 25400mm.
What am I missing?
Thanks,
Colin Holloway
You might want to run the -DWGUNITS command (include the hyphen)
to confirm that the drawing database units are what you expect them to be.
I have just checked the drawing units using the -DWGUNITS as suggested and all is set to metric and millimeters as expected.
Well that is good news, there are a whole lot of folks who would be surprised by
what they might learn if they took that simple step.
It was worth a shot, congratulations for having gotten that right :beer:
It is very important to nail down all the parameters before attacking any problem.
I agree! I also checked that MEASUREMENT and MEASUREINIT were both set to 1. Any more thought?
