Elevator Man Posted June 11, 2013 Share Posted June 11, 2013 Is it possible to make a pull down inside of a attributed block? For example: if I a have engineering code section of a title block and I want to be able to choose from a list of codes: ASME A17.1-2004 ASME A17.1-2007 ASME A17.1-2010 ASME A17.1-2012 Can I set up the block to let me do that? Quote Link to comment Share on other sites More sharing options...
pendean Posted June 12, 2013 Share Posted June 12, 2013 Not a pull down, but you could create and use a Dynamic Block. Quote Link to comment Share on other sites More sharing options...
steven-g Posted June 12, 2013 Share Posted June 12, 2013 I would use something like this. Drop Down.dwg Quote Link to comment Share on other sites More sharing options...
Elevator Man Posted June 12, 2013 Author Share Posted June 12, 2013 CAB TITLE.dwg Thanks! But that's not really what I need, as you can see with the attached block it would be less complicated to just continue doing what I'm doing now I guess. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
