It appears AutoCad changes it every three years so we can't do that? At least older programs reading newer files.
Mark
Hi Mark, I am not sure where you are going with this. Current AutoCAD has no problem reading older DWG files. It also has a good range of DWG versions that it can save back to.
It's is also able to export out to a wide range of other formats if needed.
Just letting you know. Good to hear that DraftSight seems to be working for you. :)
Good info from Dana on TrueView/TrueConvert. Good utilities to have on hand.
Sean
  • Replies 100
  • Nayfb
    25
  • ReMark
    24
  • f700es
    20
  • PotGuy
    8
Posted Images
