CaptAwesome Posted May 31, 2013 Posted May 31, 2013 (edited) Hello All Yet another NOOB here looking for a little help is possible. I am drawing up my hull and I am trying to render all boards to be just Pressboard. Some come out green some white, and at 1 time the main center was the pressboard but it no longer is. I am sure I have something garbled and I looked through the threads. a point in the right direction would be swell THX all ACV Hull.dwg Edited May 31, 2013 by CaptAwesome Adding pic Quote
iskalipsi Posted June 3, 2013 Posted June 3, 2013 I don't think this is the rendered picture. Have you applied materials to your model? Quote
CaptAwesome Posted June 5, 2013 Author Posted June 5, 2013 Yes I have applied materials and this view is under the realistic view as well. Rather than trying to figure out how to fix it, is there a way I can put all colors,materials, etc back to default? as in clear or white Thx Everyone Quote
Titi95 Posted June 5, 2013 Posted June 5, 2013 hello you were in the side that block I've broken down (sorry for my broken English) ACV Hull1.dwg Quote
iskalipsi Posted June 7, 2013 Posted June 7, 2013 Try to look at these links http://www.cadtutor.net/forum/showthread.php?35742-Rendering-in-AutoCAD-2008-2009-any-in-depth-tutorials&highlight=render http://www.cadtutor.net/forum/showthread.php?2040-Rendering-Tutorials&highlight=rendering Quote
Titi95 Posted June 7, 2013 Posted June 7, 2013 It is not rendering the problem. This is done as solid block and were not accepted texture. Quote
