darris07 Posted November 19, 2008 Posted November 19, 2008 im starting a new revit file and every time i try to import a cad dwg into revit it kicks me off. ive tried to do this at least 10 times and i have to restart the program over and over. is this something common? am i doing something wrong? pls shed some light Quote
JRevit Posted November 19, 2008 Posted November 19, 2008 what sort of cad file are you tring to import? Quote
JRevit Posted November 19, 2008 Posted November 19, 2008 dxf, dwg? autocad native? does the file have xrefs? what is the error in Revit? Quote
darris07 Posted November 19, 2008 Author Posted November 19, 2008 its the original dwg file. no exrefs. no visible error in revit. im just kicked off everytime i try to import Quote
mcklem Posted December 5, 2008 Posted December 5, 2008 maybe a memory issue ?? Im not sure .... Quote
ARCHdoc Posted February 9, 2009 Posted February 9, 2009 Sounds like it could be and install bug error. Might need to file a support request with Autodesk or uninstall and reinstall your revit. Quote
RfOeCnKdOeNr Posted February 19, 2009 Posted February 19, 2009 Is it an AutoCAD Architecture file using smart walls and AEC Objects? In my experience Revit can have problems with that. If it is then export it in AutoCAD to ACAD 2000 format and see what happens. If not, then most likely an install problem as the previous post said. Quote
