I am new to using Tool Palettes. I have created a folder on my C: drive which contains all my tool palettes. Right now, I get the symbol of a circle with a line drawn through it and cannot use my tool palettes.
In the Options tab, I noticed that there are the "Tool Palettes File Locations" and also "Authoring Palette File Locations". What is the difference between the two? Do I need to do something to both so I can use my tool palettes without difficulty? I would really appreciate your help.
Authoring palette is location for 'authoring palette' in block editor. You know, to create dynamic blocks...
