Jessica28 Posted May 30, 2013 Posted May 30, 2013 Does anyone know how I can change the color of all layers at once to the same color easier then what I'm doing now?...I open the layer manager, select all layers, click on the color and edit it globally there. Then I exit out of the layer manager....is there a routine that would do it with way less steps?...I'd try and create one but I've tried in the past and always seem to screw it up...Maybe someone knows of something already created.. Thanks Quote
eldon Posted May 30, 2013 Posted May 30, 2013 If you can handle a bit of typing, use the keyboard and type the characters in red , with a few Enters. Command: -la -LAYER Current layer: "0" Enter an option [?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: c Enter color name or number (1-255): 8 Enter name list of layer(s) for color 8 : * Enter an option [?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: Quote
BlackBox Posted May 30, 2013 Posted May 30, 2013 Written quickly: (defun c:ChangeAllLayersColor (/ color) (princ "\nSelect replacement layer color: ") (if (setq color (acad_colordlg 1 nil)) (command "._-layer" "color" color "*" "") ) (princ) ) ... This not only adds a layer of context via color select dialog, but also supports LAYERP, and UNDO Command functionality as well. Quote
BlackBox Posted May 30, 2013 Posted May 30, 2013 Great. Thanks You're welcome; I'm always happy to help. Quote
