haseebsarwar42 Posted May 29, 2013 Posted May 29, 2013 hi, if i am drawing a map in Revit Architecture and i need some structure drawing then what should i need to use Revit Structure or is there some other way? thanks in adv haseeb Quote
Lee Roy Posted May 29, 2013 Posted May 29, 2013 To use Revit Structure, you need the software, a serial number and the knowledge to use the program. if you have Revit 2013+, there's a one-box version that has all the disciplines within it. Seeing as you're using RAC, I assume your computer is already up-to-snuff and can handle RST. Quote
