Hi,
I have been searching for a lisp to export txt to excel.
Every lisp i've come across doesn't quite cut it.
We use AutoCAD LT 2013 and AutoCAD 07.
I want from every txt object (of a certain layer) the content + the X and Y coordinates.
Hope that you guys cab help me out.
Greetz,
TekenaarNL
AutoCAD LT doesn't support LISP, have you tried the DataExtract tools?
Hi,
I am using following routine in Autocad 2007 to export text with X & Y ID,
I hope this what you were looking for......:thumbsup:
(defun c:EXT (/ file dta p i)
;;; Creat CSV File
 (if (and
(setq
  file (open (getfiled "specify output file" "c:/" "csv" 1) "w")
(setq dta (ssget '((0 . "text,mtext"))))
     (write-line
"Sr No,X-Coord ,Y-Coord ,Text Value"
file
     (princ "Initial number of point ID <")
     (princ no)
     (princ ">:")
     (setq nno (getint))
     (if (= nno nil)
(terpri)
(setq no nno)
     (setq no (- no 1))
     (terpri)
     (princ
"Sr No  X-Coord   Y-Coord   Text   "
     (repeat (setq i (sslength dta))
(setq eb (entget (ssname dta (setq i (1- i)))))
(setq p (cdr (assoc 10 eb)))
(setq txv (cdr (assoc 1 eb)))
(setq no (+ no 1))
(terpri)
(princ "  ")
(princ no)
(princ ".   ")
(princ (rtos (car p) 2 3))
(princ "  ")
(princ (rtos (cadr p) 2 3))
(princ "    ")
(princ txv)
;;;Output Details of CSV file
(write-line
  (strcat (rtos no 2 1)
	  (rtos (car p) 2 3)
	  (rtos (cadr p) 2 3)
	  txv
  file
     (close file)
 (Princ)
(princ
 "\n 		    Type >EXT< to run this Routine"
I know that LT doesn't support LISP, that's wy I also use CAD 2007 (standard version).
The Dataextract in 2007 doesn't work.
None of the cad tools do the trick.
___________________________________________________________________________________________________________________________
AutoCAD LF 2013: G.204.0.0 SP2
AutoCAD 2007: V1.0
Thnx Satishrajdev !
It did the trick :D.
I m glad to heard that... :)
  • 2 years later...
Hi satishrajdev,
Thank you for the code!
This is what i need :)
Hope you have a good day, man
  • 2 years later...
Hi,
;;; Creat CSV File
 (if (and
(setq
     (write-line
file
     (princ no)
     (princ ">:")
     (setq nno (getint))
     (if (= nno nil)
(terpri)
(setq no nno)
     (setq no (- no 1))
     (terpri)
     (princ
(setq no (+ no 1))
(terpri)
(princ "  ")
(princ no)
(princ ".   ")
(princ "  ")
(princ "    ")
(princ txv)
(write-line
	  (rtos (car p) 2 3)
	  (rtos (cadr p) 2 3)
	  txv
  file
     (close file)
 (Princ)
(princ
Fantastic code!
I'd like to insert just the selected texts from excel.
Is it possible?
Thanks
If you want direct to excel no problems, there is just so many examples out there just google Autocad to excel.
Thank you for advice.
I'm going to searching a code on the google.
  • 1 year later...
On 27/05/2013 at 15:04, satishrajdev said:
Hi,
;;; Creat CSV File
 (if (and
(setq
     (write-line
file
     (princ no)
     (princ ">:")
     (setq nno (getint))
     (if (= nno nil)
(terpri)
(setq no nno)
     (setq no (- no 1))
     (terpri)
     (princ
(setq no (+ no 1))
(terpri)
(princ "  ")
(princ no)
(princ ".   ")
(princ "  ")
(princ "    ")
(princ txv)
(write-line
	  (rtos (car p) 2 3)
	  (rtos (cadr p) 2 3)
	  txv
  file
     (close file)
 (Princ)
(princ
Hi,
;;; Creat CSV File
 (if (and
(setq
     (write-line
file
     (princ no)
     (princ ">:")
     (setq nno (getint))
     (if (= nno nil)
(terpri)
(setq no nno)
     (setq no (- no 1))
     (terpri)
     (princ
(setq no (+ no 1))
(terpri)
(princ "  ")
(princ no)
(princ ".   ")
(princ "  ")
(princ "    ")
(princ txv)
(write-line
	  (rtos (car p) 2 3)
	  (rtos (cadr p) 2 3)
	  txv
  file
     (close file)
 (Princ)
(princ
How can i use this code in autocad
