hosyn Posted May 24, 2013 Share Posted May 24, 2013 Any suggestion for copy objects to new layers by lisp ?? Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 25, 2013 Share Posted May 25, 2013 Start here: (Command "CopyToLayer") Quote Link to comment Share on other sites More sharing options...
hosyn Posted May 25, 2013 Author Share Posted May 25, 2013 (edited) So thanx to your attention Edited May 25, 2013 by hosyn Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 25, 2013 Share Posted May 25, 2013 You may need to take a deep look into the following thread which is hasn't been discussed long a go . http://www.cadtutor.net/forum/showthread.php?79266-copy-rename-layer Quote Link to comment Share on other sites More sharing options...
hosyn Posted May 25, 2013 Author Share Posted May 25, 2013 (edited) thanxxxxxxxxxxxxxxxxxxxxxxxx a lot Edited May 25, 2013 by hosyn Quote Link to comment Share on other sites More sharing options...
hosyn Posted May 25, 2013 Author Share Posted May 25, 2013 (edited) thanxxxxxxxxxxxxxxxxxxxxx Edited May 25, 2013 by hosyn Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 25, 2013 Share Posted May 25, 2013 Try this code and hope you do not remove the author name of the code . (defun c:Test (/ *error* showdcl on lst ss i sn vl) ;;;--- Tharwat 25. May. 2013 ---;;; (or doc (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) ) (defun *error* (x) (if doc (vla-endundomark doc) ) (if f (progn (close f) (vl-file-delete fn)) ) (princ "\n*Cancel*") ) (defun ShowDcl (/ sn f str dcl_id l lays pos) (setq fn (vl-filename-mktemp "dcl.dcl")) (setq f (open fn "w")) (foreach str (list "Layers : dialog { label = \"Layer List\"; fixed_width = true;" ": list_box { label = \"Select Layer\"; key = \"layer\"; width = 32; multiple_select = true;}" ": boxed_row { label = \"Action\";" ": row {" ": button { label = \"Accept\"; key = \"accept\"; is_default = true; }" ": button { label = \"Cancel\"; key = \"cancel\"; is_cancel = true; }}}}") (write-line str f) ) (close f) (setq dcl_id (load_dialog fn)) (if (not (new_dialog "Layers" dcl_id)) (exit) ) (while (setq l (tblnext "LAYER" (not l))) (setq lays (cons (cdr (assoc 2 l)) lays)) ) (setq lays (reverse lays)) (start_list "layer") (mapcar 'add_list lays) (end_list) (action_tile "accept" "(setq pos (get_tile \"layer\"))(done_dialog)" ) (action_tile "cancel" "(done_dialog)") (start_dialog) (unload_dialog dcl_id) (if pos (foreach n (read (strcat "(" pos ")")) (setq lst (cons (nth n lays) lst)) ) ) ) (if (and (progn (princ "\n Select Polyline ...") (setq ss (ssget "_:L" '((0 . "*POLYLINE")))) ) (setq on (ShowDcl)) ) (progn (vl-file-delete fn) (vla-StartUndomark doc) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i)))) (foreach x lst (vla-copy (setq vl (vlax-ename->vla-object sn))) (vla-put-layer vl x) ) ) (vla-endundomark doc) ) ) (princ "\n Written By Tharwat Al Shoufi") (princ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 25, 2013 Share Posted May 25, 2013 Here is an example: ([color=BLUE]defun[/color] c:c2lay ( [color=BLUE]/[/color] inc lay lst obj sel ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color])) ([color=BLUE]progn[/color] ([color=BLUE]while[/color] ([color=BLUE]setq[/color] lay ([color=BLUE]tblnext[/color] [color=MAROON]"layer"[/color] ([color=BLUE]not[/color] lay))) ([color=BLUE]if[/color] ([color=BLUE]zerop[/color] ([color=BLUE]logand[/color] 52 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 70 lay)))) ([color=BLUE]setq[/color] lst ([color=BLUE]cons[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 lay)) lst)) ) ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] lst (LM:listbox [color=MAROON]"Select Layers to Copy to"[/color] ([color=BLUE]acad_strlsort[/color] lst) [color=BLUE]t[/color])) ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] inc ([color=BLUE]sslength[/color] sel)) ([color=BLUE]setq[/color] obj ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] inc ([color=BLUE]1-[/color] inc))))) ([color=BLUE]foreach[/color] lay lst ([color=BLUE]vla-put-layer[/color] ([color=BLUE]vla-copy[/color] obj) lay) ) ) ([color=BLUE]princ[/color] [color=MAROON]"\n*Cancel*"[/color]) ) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) You will need to download and load my List Box function before running the above. Quote Link to comment Share on other sites More sharing options...
LibertyOne Posted May 30, 2013 Share Posted May 30, 2013 thanxxxxxxxxxxxxxxxxxxxxxxxx a lot Kisses for Tharwat Quote Link to comment Share on other sites More sharing options...
alanjt Posted May 30, 2013 Share Posted May 30, 2013 As BlackBox said, COPYTOLAYER. No need for code. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 30, 2013 Share Posted May 30, 2013 As BlackBox said, COPYTOLAYER. No need for code. *Tips hat* Quote Link to comment Share on other sites More sharing options...
alanjt Posted May 30, 2013 Share Posted May 30, 2013 *Tips hat* likewise Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 31, 2013 Share Posted May 31, 2013 Kisses for Tharwat ..... Quote Link to comment Share on other sites More sharing options...
darwinland Posted October 27, 2016 Share Posted October 27, 2016 The routine of Tharwat works perfectly, but could be adapted to select all objets in the layer of the object selected. Thax Quote Link to comment Share on other sites More sharing options...
darwinland Posted October 27, 2016 Share Posted October 27, 2016 Here is an example: ([color=BLUE]defun[/color] c:c2lay ( [color=BLUE]/[/color] inc lay lst obj sel ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color])) ([color=BLUE]progn[/color] ([color=BLUE]while[/color] ([color=BLUE]setq[/color] lay ([color=BLUE]tblnext[/color] [color=MAROON]"layer"[/color] ([color=BLUE]not[/color] lay))) ([color=BLUE]if[/color] ([color=BLUE]zerop[/color] ([color=BLUE]logand[/color] 52 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 70 lay)))) ([color=BLUE]setq[/color] lst ([color=BLUE]cons[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 lay)) lst)) ) ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] lst (LM:listbox [color=MAROON]"Select Layers to Copy to"[/color] ([color=BLUE]acad_strlsort[/color] lst) [color=BLUE]t[/color])) ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] inc ([color=BLUE]sslength[/color] sel)) ([color=BLUE]setq[/color] obj ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] inc ([color=BLUE]1-[/color] inc))))) ([color=BLUE]foreach[/color] lay lst ([color=BLUE]vla-put-layer[/color] ([color=BLUE]vla-copy[/color] obj) lay) ) ) ([color=BLUE]princ[/color] [color=MAROON]"\n*Cancel*"[/color]) ) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) You will need to download and load my List Box function before running the above. Why do I need the list box? Thx Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 27, 2016 Share Posted October 27, 2016 Why do I need the list box?Thx Because the function 'LM:listbox' will otherwise be undefined. Quote Link to comment Share on other sites More sharing options...
darwinland Posted October 28, 2016 Share Posted October 28, 2016 Because the function 'LM:listbox' will otherwise be undefined. I have both code on my contents file, but when I run c2lay I select a item and then stops the routine without any result. Can you help me Best regards Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 28, 2016 Share Posted October 28, 2016 when I run c2lay I select a item and then stops the routine without any result. Is the dialog displayed? Do you receive any error messages at the command-line? Quote Link to comment Share on other sites More sharing options...
darwinland Posted October 28, 2016 Share Posted October 28, 2016 Is the dialog displayed?Do you receive any error messages at the command-line? No, nothing happens, no pop ups, I select an object and stops Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted October 28, 2016 Share Posted October 28, 2016 Is the object on a locked layer? Quote Link to comment Share on other sites More sharing options...
