Dustin11 Posted May 24, 2013 Posted May 24, 2013 I have this rough draft code I'm building to be used as a layer checker but I also need to to loop through once using the first item in the list, then loop through a second time using the second item on the list, then a third, fouth, etc..... but I can't seem figure out a way to make it do that. I'm also pretty sure that where I have the "repeat" function is incorrect because after I added it the code stopped working, but I haven't tried messing around with that to get it working again. (defun c:mscheck (/ sys ss count msg) (setq sys (list "H-LOWP")) (setq sys (append sys '("H-LOWP-EXST" "H-MEDP" "H-MEDP-EXST" "H-EXHS" "H-EXHS-EXST" "H-GRDS" "H-GRDS-EXST" "H-RTRN" "H-RTRN-EXST" "G-GENL-TEXT" "G-GENL-TEXT-EXST" "G-EQPM" "G-EQPM-EXST" "H-STAT" "H-STAT-EXST" "H-OAIR" "H-OAIR-EXST"))) (setq count (length sys)) (repeat count (if (tblsearch "layer" sys)foreach (progn (setq ss (ssget "_X" (list (cons 8 sys)))) (if (= ss nil) (progn (setq count "0") );progn (progn (setq count (sslength (ssget "_P"))) );progn );if );progn (progn (setq count "DNE") );progn );if (setq msg (cons sys count)) (print msg) (princ) );repeat );defun Quote
BlackBox Posted May 24, 2013 Posted May 24, 2013 (defun c:FOO (/ ss) (foreach layerName '("H-LOWP" "H-LOWP-EXST" "H-MEDP" "H-MEDP-EXST" "H-EXHS" "H-EXHS-EXST" "H-GRDS" "H-GRDS-EXST" "H-RTRN" "H-RTRN-EXST" "G-GENL-TEXT" "G-GENL-TEXT-EXST" "G-EQPM" "G-EQPM-EXST" "H-STAT" "H-STAT-EXST" "H-OAIR" "H-OAIR-EXST" ) (prompt (strcat "\n[" layerName "] : " (if (setq ss (ssget "_x" (list (cons 8 layerName)))) (itoa (sslength ss)) "0" ) ) ) ) (textpage) (princ) ) Quote
Dustin11 Posted May 24, 2013 Author Posted May 24, 2013 Nice. it works perfectly. I'll have to dissect your code a littie bit and see what you did incase I need to write something like that again in the future. Thanks. Quote
BlackBox Posted May 24, 2013 Posted May 24, 2013 Dustin11 said: Nice. it works perfectly. I'll have to dissect your code a littie bit and see what you did incase I need to write something like that again in the future. Thanks. You're welcome; I'm happy to help. Essentially, Foreach layerName in the list of layerNames, Prompt the user the layerName, and If there are Entities on that layer, include how many, Else zero. Quote
