Can you upload a drawing, because that isn't a solution it's a fudge, without seeing a dwg it's hard to say which setting is incorrect.
  • Replies 26
  • jacktopus
    10
  • ReMark
    8
  • rkent
    3
  • feargt
    3
Is 1:30 even considered a standard metric scale?
Unfortunately I cant, it's company work and I can't display it, also Its unavailable until tomorrow morning.
Then I guess we're done here. Thanks.
  jacktopus said:
my title block is in PS (paper space) and what do you mean by metric title block? isnt a title block just a title block?
An imperial title block might measure 36x24, a close metric equivalent is A1 and would measure 841x594. If you are drawing in mm then your titleblock needs to be in a metric size also drawn to mm, otherwise the scale for a viewport makes no sense.
So I ask you again, what are the dimensions of your titleblock?
  jacktopus said:
scalelistedit might work, Have to go back and edit my drawings, Thanks
Nope, it is not relevant to what scale you have drawn at, it only lets you add or delete scales for plotting.
