Hippe013 Posted May 23, 2013 Posted May 23, 2013 Hello everyone! Just as the title says I am looking to attach an xref to each layout in my open drawing. I am currently using Civil3D 2013. My current code is as follows: (defun c:XREF-LAYOUT (/ fp xrname PS LOs AD) (setq fp (getfiled "Select External Reference: " "" "dwg" 0)) (if (/= nil fp) (progn (setq xrname (vl-filename-base fp)) (setq PS (vla-get-paperspace (setq AD (vla-get-activedocument (vlax-get-acad-object))))) (setq LOs (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))) (vlax-for lo LOs (if (/= "Model" (vla-get-name lo)) (progn (vlax-put-property AD 'ActiveLayout lo) (setq xr (vla-AttachExternalReference PS fp xrname (vlax-3d-point (list 0 0 0)) 1. 1. 1. 0. :vlax-false)) ) ) ) ) ) ) I keep getting this error: ; error: Exception occurred: 0xC0000005 (Access Violation) ; warning: unwind skipped on unknown exception Any help would be appreciated. Quote
Lee Mac Posted May 24, 2013 Posted May 24, 2013 (edited) Try this: (defun c:xrl ( / acd acl dwg ins xrn ) (if (setq dwg (getfiled "Select XRef" "" "dwg" 16)) (progn (setq acd (vla-get-activedocument (vlax-get-acad-object)) acl (vla-get-activelayout acd) xrn (vl-filename-base dwg) ins (vlax-3D-point 0 0) ) (vlax-for lay (vla-get-layouts acd) (if (/= "MODEL" (strcase (vla-get-name lay))) (progn (vla-put-activelayout acd lay) (vla-attachexternalreference (vla-get-paperspace acd) dwg xrn ins 1.0 1.0 1.0 0.0 :vlax-false) ) ) ) (vla-put-activelayout acd acl) ) ) (princ) ) (vl-load-com) (princ) Edited August 30, 2022 by Lee Mac 1 Quote
Hippe013 Posted May 24, 2013 Author Posted May 24, 2013 (edited) Hey Lee, Thanks for the reply. Though in the mean time I ended up getting it to work. My revised code is as follows: (defun c:xrl (/ fp xrname AD PS LO l PS) (setq fp (getfiled "Get Xref" "" "dwg" ) (setq xrname (vl-filename-base fp)) (setq AD (vla-get-ActiveDocument (Vlax-get-acad-object))) (setq LO (vla-get-layouts AD)) (vlax-for l LO (if (/= "Model" (vla-get-name l)) (progn (vla-put-ActiveLayout AD l) (princ (strcat "\n***" (vla-get-name l) "***\n")) (setq PS (vla-get-block l)) (setq xr (vla-AttachExternalReference PS fp xrname (vlax-3d-point '(0 0 0)) 1. 1. 1. 0. :vlax-false)) ) ) ) (princ) ) Edited May 24, 2013 by Hippe013 Quote
Lee Mac Posted May 24, 2013 Posted May 24, 2013 (edited) Here is another method to avoid the need to switch layouts: (defun c:xrl ( / acd dwg ins obj xrn ) (if (setq dwg (getfiled "Select XRef" "" "dwg" 16)) (progn (setq acd (vla-get-activedocument (vlax-get-acad-object)) xrn (vl-filename-base dwg) ins (vlax-3D-point 0 0) obj (list (vla-attachexternalreference (vla-get-modelspace acd) dwg xrn ins 1.0 1.0 1.0 0.0 :vlax-false)) ) (vlax-for lay (vla-get-layouts acd) (if (/= "MODEL" (strcase (vla-get-name lay))) (vlax-invoke acd 'copyobjects obj (vla-get-block lay)) ) ) (vla-delete (car obj)) ) ) (princ) ) (vl-load-com) (princ) Edited August 30, 2022 by Lee Mac Quote
